Go Back  Offshoreonly.com > Boating by Region > Northeast US
Northern NJ spots >
Northern NJ spots
Northern NJ spots
Old 05-23-2006 | 07:53 AM
  #1121
hunster's Avatar
Default Re: Northern NJ spots
Originally Posted by Panther
Mr V, I have a question I've been dying to ask you.
Do you change the winter and summer air in your tires because that winter air has been known to cause serious tire wear in July.
Just rotate the air! that saves all the tire wear! Where do you recycle that used air anyway?
hunster is offline
Old 05-23-2006 | 08:48 AM
  #1122
Panther's Avatar
Frank's Marine Service
Shoot.. Summer is almost here, I better get on that!
Panther is offline
Old 05-23-2006 | 08:55 AM
  #1123
mr_velocity's Avatar
Not only do I change the air, I put fragrance in it too. Really nice smelling stuff that matches the pink boat.
mr_velocity is offline
Old 05-23-2006 | 09:00 AM
  #1124
Originally Posted by rastaboatin
What?? Do you shrink wrap the boat if it is sitting for more then a week too? Who said it was a good idea to leave your engine with no oil all winter? I am just asking it does not seem like a good idea. Winter and summer air? explain please
Why is it a bad idea? What good is 14qts sitting in the pan going to do for anything other than perhaps the pan?
With my setup I can pump clean oil through the entire motor including the oil coolers before I do the drain. So all the surfaces have clean oil.
Surface rust happens pretty quick so it's not a bad idea to give the motors a light fogging. I have a full cover for the summer so I don't need to shrink it. Although last year I was way to lazy to put it on after every use.
Old 05-23-2006 | 09:03 AM
  #1125
Make sure if you rotate the tires you keep the air spinning in the same direction. Otherwise you'll have to replace that air too.
And keep running the boat so when I'm ready to go all the stale gas has been bought and burnt by you. You're worried about me leaving the motors dry, I'd be more worried about running crap gas being the first one on the water. And with all those hours you had to fill up a couple of times already.
  #1126
hunster's Avatar
Talking Re: Northern NJ spots
You must be getting old! You refer to how lazy you are in almost every post! And as for sending the wife out to get your parts , thats the best way to get out of the house , go get a part! If it's not at the grove or the mall mine won't go!
hunster is offline
Old 05-23-2006 | 09:07 AM
  #1127
and being lazy takes all my time.
I just find it really hard to walk past the pool to pull the cover off the boat. Once I hear some boats running in the river I'll get motivated. But so far it's been pretty quiet.
Old 05-23-2006 | 09:25 AM
  #1128
hunster's Avatar
You can't hear me! That stealth stock exhaust. Checked my warehouse and they have hp6's in stock , 23 ea. Also looked at the redline stock and looks like everything is in stock too. checked the pricing and looks like 10.56 qt most oils. let me know if it helps , I get a delivery every weekday!
hunster is offline
Old 05-23-2006 | 10:13 AM
  #1129
sakoutis3's Avatar
Mr V. you just weren't listening hard enough. My trps. roared past Monmouth Beach twice this weekend ocean side. By the time you get the energy to pump some gas in that boat Chuck will have sold me two truck loads of 93.
sakoutis3 is offline
Old 05-23-2006 | 10:36 AM
  #1130
Panther's Avatar
Really nice smelling stuff that matches my pink kayak.
Panther is offline
