Go Back  Offshoreonly.com > Boating by Region > Northeast US
Northern NJ spots >
Northern NJ spots
Northern NJ spots
Old 05-22-2006 | 12:42 PM
  #1101
Panther's Avatar
Frank's Marine Service
Default Re: Northern NJ spots
Nice!
Panther is offline
Old 05-22-2006 | 01:23 PM
  #1102
mr_velocity's Avatar
Originally Posted by Panther
From the sounds of things it looks like the only boating you'll be doing is on the resin bucket this year.
See ya on the 4th of July! Wait, that's just in time for your annual run to the Dippells.
Come on dude, stop procrastinating and cut the cover off. We can have that boat running in 1 hr...... Like you said, "All I have to do is cut the cover off and turn the key..."
install the batteries and fill the motors with oil. I think I need filters, anyplace local I can get hp6 filters? At least the props are already on
mr_velocity is offline
Old 05-22-2006 | 01:47 PM
  #1103
Is the Tiki bar also known as the sand bar??
CasinoRunner is offline
Old 05-22-2006 | 01:48 PM
  #1104
Mr V.,
Not sure if it's local to you but lockwood boatworks usually has or can get what you need.
Old 05-22-2006 | 01:53 PM
  #1105
sakoutis3's Avatar
Yes the Tikki bar is the Sand bar.
sakoutis3 is offline
Old 05-22-2006 | 01:55 PM
  #1106
Panther's Avatar
Fill the motors with oil??? Is that so the inside of your oil pans get nice a rusty over the winter?
Please don't tell me you keep them dry? Keeping the old oil in there is better than keeping it dry.
Panther is offline
Old 05-22-2006 | 02:20 PM
  #1107
sakoutis3's Avatar
I hope he meant change the oil otherwise
Old 05-22-2006 | 05:07 PM
  #1108
Errr, nope. Motors have been empty for every winter for the past 7 years. Just drain what little is left in the bottom, fill them up, spin on a new HP6 filter, fire the pre-lubers and turn the key. Just the way I like it
Had a long emial thread with panther this afternoon on the subject, the only reason he could come up with is rust in the pan. Well the pan is well coated with oil, as is everything else. 14 qts sitting in the pain isn't going to stop condensation and any water is going to the bottom anyway.
For years I ran RedLine Race oil, no detergents. Everyone said I was crazy. With 20 hour changes it worked fine. I have a lot of WOT time on the motors. As Panther pointed out I need to run hard to keep up. I am not afraid to keep the throttle pinned. We ran the entire NYC poker run one year WFO, same motors are still running strong. When Billy had your boat I ran Belmar to SH WFO, been doing it since he had the 45 Sonic. 5400 is the sweet spot Pulled the upper end last year to change the springs, there isn't a sign of rust anywhere.
I generally fog the motors if they will sit for more than a week. Panther said your going to foul plugs Never been a problem either.
Besides I don't what to have to change the oil in the spring again to summer oil.....about the same time I change the air in the tires to summer air
Old 05-22-2006 | 06:44 PM
  #1109
Panther's Avatar
Maybe some of the builders will respond?????
Seems pointless IMHO.
Panther is offline
Old 05-22-2006 | 07:27 PM
  #1110
Thought I was going to be able to post tonight that I cut the cover........but it didn't happen. Just too damn cold to be thinking about the boat. Hopefully it will be a nice weekend and I'll hear someone run, that would get me wanting to cut it.
Need to get a few people to come over and piss off the neighbors again, let'em know summer is here
