Northern NJ spots
#421
Originally Posted by Panther
Garry, thanks for dinner and the hospitatlity! It was a great run, lot's of fun!
I think I left my chew toy at your house, can you bring it down to the boat for me tomorrow AM? Hopefully, you'll join us as the rendezvous point on the river tomorrow.
Yes, it's true we ran together on the OCEAN today. I must admit thought, I never had to cruise that slow.
Then on the way home, even with a bad engine coupler, only running 4700 rpms, we were walking away from the potato chip who was running WOT. He saw a lot of this today!
Yea it was a slow run, but you were setting the pace.
#422
Originally Posted by CasinoRunner
More ICW pics, look at this bridge. It's real low
, but you gotta know your boat.
Mr. V doesnt use a VHF so I said what the heck............
#423
[QUOTE=njgr8ful] Bad coupler Frank
Can you get that by sliding engine back or is that a pull job?
[QUOTE]
Yeah, when I blew the drive a few weeks ago apparently I f'ed up the engine coupler too. It's holding together for now but for how long I don't know. I'm going to replace it this week.
It's about a 4 hr job. Drive has to be pulled, then the engine. The engine should'nt be out of the boat for more than 20 minutes, then back in she goes! It's a fairly easy job, just a pain in the A$$.
No pics yesterday, I think Mr. V. left the camera at home on purpose.
[QUOTE]Yeah, when I blew the drive a few weeks ago apparently I f'ed up the engine coupler too. It's holding together for now but for how long I don't know. I'm going to replace it this week.
#424
Originally Posted by mr_velocity
I had to let you run just in front of me, my neck was geting sore turning around all the time to see if you were able to keep up
[QUOTE=mr_velocity]I had to let you run just in front of me, [QUOTE]
I thought you were going to say that you couldn't hear so well because I was out in front of you all day!
Like Ari said,, "Your boat is LOUD, it was pissing me off!"
#425
By the way Mr. V, my father said that you should take the boat to El Salvador. He said you would have the fastest fishing boat, and they give out free potato chips!
#426
Mr V. ,
Friday did not work out for me.
I launched the boat at 3:30 pushed off the dock and it wouldn't go into gear- forward and reverse didn't work.
Luckily I had an extra long pole and was able to reach the dock. I trailered it back to Navesink that evening.
Panther,
Your boat looked real clean (Friday evening), must have just missed you.
Luckily I had an extra long pole and was able to reach the dock. I trailered it back to Navesink that evening.Panther,
#427
Casino, it's probably an easy fix. When they installed the drive the shift cable may not have latched in properly. It may be as simple as loosening the drive, pulling it out a little bit, hooking up the cable and putting it back on. I wouldn't sweat it.
#428
It should have been tested before the boat left....
#429
Yes it should have. As far as that cable?? I'm not sure it's that because it worked after the drive was serviced. I took it out and used it that foggy day. John said they replaced the top cap only....so we will see. I want them to test it before I take it back. Maybe they will put me in the water there and you could come out for a ride.
It could also be the barrell that holds the shift cable inside the plastic linkage. I've seen them pull out, it's a two minute fix. If you're down at the marina today, I can take a quick look for you.
I'll PM you my cell #, should be there in about an hour or so.
#430
Video...idle speed.....no boats
http://www.putfile.com/media.php?n=ocean73005_0002
