Go Back  Offshoreonly.com > Race Talk > Offshore Super Series (OSS)
F1 motor option discussion >
Old 09-13-2003 | 01:08 PM
TYPHOON's Avatar
Default F1 motor option discussion
We have a good handle on the rest of the rules we all want for are class. Now for the biggest issue, the motor for F1.
1) must not change for 5 years
2) must be sealed
3) must be in the 510- 520 HP range Dyno
4) must be readily available
5) must be rebuildable aprox $3500
6) Purchase price sealed less than $14,000
7) must come with support from builder
8) must have a contingency program worthy of using it.
9) must be approved buy 60% of pro series race teams.
10) must have warranty if something other than merc. 500EFI (only because of merc's track record)
I like Ginos idea of a check for $500 for each race we run with that motor!
OK lay it on me boys what should I edit or add,it's a start.
Mad Dog
TYPHOON is offline
Old 09-14-2003 | 11:41 AM
TYPHOON's Avatar
No comments?
TYPHOON is offline
Old 09-14-2003 | 01:31 PM
randy,
#1 your cutting yourself short. the rule change is 5 years and it's already in the book. #2 unless we are doing the 496 there are no other options.
the only reasonable option to me would go back to the 500 efi with xr gears and sportmaster lower. that will slow everbody down a little. and no five blade props.
we were already there. we just wen't past our mark.
the only mistake in the class is the weight rule. everbody should be 8000lbs for f2 and 4700 for f1.
Treadewell
Treadwellmotorsports is offline
Old 09-15-2003 | 08:21 AM
TYPHOON's Avatar
Changed to 5 years and there is always options.
MD
Let stick to motors for our class
TYPHOON is offline
Old 09-15-2003 | 11:33 AM
Peconic's Avatar
What book proscribes that an engine can't change for 5 years?
The general and technical rules are available at http://www.apba-offshore.com/rules.cfm , and I can't find anything along those lines. If I have overlooked it, then this whole discussion about changing to a new engine is moot. Would be against the regs ....
Peconic is offline
Old 09-15-2003 | 03:06 PM
Peconic's Avatar
Randy's List
At this writing, 156 views. And not a single objection ( I don't count 3 v.v. 5 years as an objection ...)
Can we assume that Randy's list is regarded as a workable plan?
Peconic is offline
sommerfliesby
Northern Illinois Offshore Club
7
04-11-2008 03:39 PM
xxxtreme171
Baja
13
06-14-2004 02:13 PM
CAP071
06-11-2003 10:39 AM
