Prop Advice >
Prop Advice
Prop Advice
Old 08-26-2006 | 08:38 AM
Default Prop Advice
I have a 1999 29 PQ Enticer with twin 7.4 mpi engines bravo 1 1:50 drives. I have 3 blade 25 pitch mirage plus Gps 68 mph @4400 rpm and bravo 24 pitch 4 blade 4600 rpm @ 64mph Gps. I'd love to keep the 4 blade (much better ride less chine walk) but i also would like to get some mph back. What can i do ? And do i have the right 4 blade prop? Is 4600 rpm pushing it. What is the rev limit set at ? Thanks in advance for the feedback. Jeff
paxtonsc is offline
Old 08-26-2006 | 12:27 PM
BY U BOY's Avatar
Default Re: Prop Advice
HAVE IT LABBED TO PICK UP SOME RPMS AND MAYBE A LITTLE MORE SPEED
BY U BOY is offline
Old 08-28-2006 | 04:57 PM
throttleup's Avatar
The 7.4L needs to run at 4500-4600 at WOT to ahieve max speeds, typically. However keep in mind we are assuming that the props you are testing with are true. I would agree however that you need to consider lab finishing a 26P Bravo I to run a similar RPM to that of your stock 24P Bravo I. But I don't see you going faster with the 4B than you are with the 3B. Getting 4MPH out of labbing is a tall order.
Julie
throttleup is offline
Old 08-28-2006 | 07:33 PM
bbladesprops's Avatar
Offshoreonly Advertiser
Smile Re: Prop Advice
Labbing 26 B1's is the choice I would make. The R's will be just below thge 24's and we can most likely get all or very close to the 4mph you are looking for.
[email protected]
bbladesprops is offline
NashvilleBound
Prop Talk
1
03-13-2007 08:48 AM
wheatieworld
Powerquest
1
08-06-2006 06:04 PM
fastestbowtie
7
09-07-2005 06:52 PM
89scarab3
Prop Talk
2
08-18-2005 07:09 PM
Cobra1
Prop Talk
6
04-26-2005 07:29 PM
