Help with prop to Chris Craft 260 Stinger >
Old 06-26-2020 | 01:31 AM
  #31
Originally Posted by JohanSweden
I mean it is plugged in the transom assembly, not in the drive sorry...
I will do that before I install the spacer.
And then I should try the boat again with my Bravo 1 26P propeller to see how it reacts?
You don't want it plugged at all. You want the water to flow through it and out an external hull dump.
Yes, I would do one thing at a time and then test. If you do two things, and something improves, you won't know which one caused the improvement or what direction to proceed.
Griff is offline
Old 06-26-2020 | 01:36 AM
  #32
Another option to allow water to flow through the drive is tap the water jacket and use it to feed your drive shower.
Griff is offline
Old 06-26-2020 | 01:49 AM
  #33
But if I unplug it in the transom assembly it will flow water into the boat?
I mean the original water inlet to the engine, that one is plugged and replaced with the water pickup.
I dont mean that youre not right, its just me that dont understand I think
Yes I will do that. Youre right!
I wonder if there is someone that have done this, with a extentionbox or high drive mount on a Chris Craft 260 Stinger before..?
Have tried to find any information about it but without sucess. Seems that im the ”first” and first testing with this to make it work.
But when I read about high drive mount boats they say I will need a propeller with high rake.
And a propeller with high rake will ”lift the bow” ore in correct words, lift the stern less
JohanSweden is offline
Old 06-26-2020 | 07:44 AM
  #34
What comes to propellers, it is not that simple. You have test and test! I think that your bravo prop is the one if 4 blades is enough.
JaniH is offline
Old 06-26-2020 | 09:13 AM
  #35
Yes have to test with the spacer and see if the slip goes down, and how the engine/boat reacts.
If the engine rpm is going down and the teoretical prop slip is going down then maybe have to go down in pitch?
Or leave it to someone that can lab it in some way
Old 06-26-2020 | 12:52 PM
  #36
More blades and more blade surface area increase stern lift.
The water that flows though the transom assembly gets connected to another hose and then connected to a thru hull fitting that dumps the water outside the boat.
Griff is offline
Old 06-26-2020 | 08:29 PM
  #37
Johan, is the external pick up for the intercooler? You mentioned that you have a Whipple kit on the engine.
As suggested start by trimming the pickup.
badluck is offline
Old 06-26-2020 | 10:06 PM
  #38
Is the prop completely stock untouched?
Unlimited jd is offline
Old 06-27-2020 | 01:40 AM
  #39
The whipple stage 1 is an small reprogram of the PCM not an SC and water pick up is for the engine since he said transom/drive p/u is plugged.
Griff is offline
Old 07-03-2020 | 01:04 PM
  #40
No like Griff said, the water pickup is for the closed cooling system to the engine and cooling for the headers and oil cooler I think.
I have no whipple kit on it. Just the PCM reprogram stage 1 whipple for the Mercruiser 496.
I dont think it is... it looks like it have been labbed.
Exactly
