Fountain 47, 2372cid single engine diesel >
Old 05-18-2025 | 07:23 PM
  #491
awesome project but are you sure those cv joints will hold up? i have seen many failures in the marine world
boostbros is offline
Old 05-18-2025 | 08:54 PM
  #492
Originally Posted by Twin O/B Sonic
Love it!
Great thread, as always.
I used to run a repair shop for Makita power tools and I always hated those big drills that would break your arm when they jammed!
I have those big, 4”* hole saws that will do it too!
Even longer handles to help with the torque...just get moving faster to smack you when it gets free!!!
Tartilla is offline
Old 05-20-2025 | 10:05 AM
  #493
You make every project that I think is hard seem so much more doable! Incredible project.
TxHawk is offline
Old 05-20-2025 | 02:42 PM
  #494
CONGRATS on getting the engine in! Now comes the fun part!
Looking at your tailpipe holes, what are your plans to prevent water washing backwards into the turbine housing?
VortechSS is offline
Old 05-20-2025 | 05:06 PM
  #495
Valid question. How do any of the turbo engines prevent this?
thegoodson is offline
Old 05-20-2025 | 08:52 PM
  #496
he just needs to make a bigger version of the Nikoli Tesla one way valve.
https://en.wikipedia.org/wiki/Tesla_valve
sutphen 30 is offline
Old 05-21-2025 | 10:58 AM
  #497
Static strenght for these 128mm CV joints is over three times dynamic force so safety factor is over three. Joints will die fast if there is any kind lubrication issue, I have seen big CV joint failures in small power boats, all of them have been as dry Bedouin sandal. I should remove, disassembly wash and relubricate drive shafts every year. There are some ways to improve greace runaway from joint to rubber sleeve.
ksalmine is offline
Old 05-21-2025 | 11:16 AM
  #498
Exhaust are ready, this way I sealed big holes.
First I weld 12 degree angle parts to get tails in right spot. Engine is also adjusted to level.
2mm thick silicon sheet, it can handle near 300C temps so it's good sealing material. It doesn't matter if some day there is little tailpipe overheating issue. Silicon is also very flexible and stretchy so it can be slip over pipe.
Stainless steel water cut flange push ***** lip against to transom, should be pretty watertight.
I try find black silicon but red was only available, color doesn't matter now because splash is so close. No time to lose!
As you see, pipes are litte up in holes, there is little tolerance to adjust driveshafts more in line (lift splitbox side of powerline up) if boat needs bigger trim angle. Engine is now set 2 degree trim angle to get CV joints as little angle as possible.
Carbon tube end turning to straight, there is special tool locked inside tube to get support for outer end.
CrMo end pieces pressed in and first one is now glued! Another will be glued tomorrow, soon I can assemble CV's and put shafts in boat.
Nobody know how these hold up but if my calculations are right, glue joint have 40 times safety factor and tubes should hold two times the power. Transmash will be in good tune if it have so much power to explode carbon tube.....
ksalmine is offline
Old 05-21-2025 | 11:27 AM
  #499
Don't you passivate stainless steel welds?
plavutka is offline
Old 05-21-2025 | 11:52 AM
  #500
Omg! I’ve got a lot of reading to do. How much torque/hp is your engine going to make? Do you have an estimated top end? I know this has been covered already and I apologize for my laziness. ​​​​​
Eddienel is offline
