Go Back  Offshoreonly.com > Owners Forum > Saber
Saber 101 >
Saber 101
Saber 101
Old 10-16-2011 | 08:25 PM
  #81
KNOT-RIGHT's Avatar
Originally Posted by hotjava66
Have had best results with 3 blade props, running old school mirage right now. Prop shafts are appx 6.5" below corresponding hull bottom. Maybe your drive or drive placement doesnt allow the leverage to carry the bow well? Or is set for too much positive trim? Trimmed all the way down I get no porpise at any speed, but at low speed any added positive trim will induce a serious propise. I would try a 3 or 4 blade prop if you have an appropriate sized one you can use.
Wow great info i realize we are talking twins. However 2.5 inches deeper. I would love to see a side shot of the drive all trimmed in.
Three blade prop was mentioned to Art Then he Sh@t himself on the idea. LOL. But I think a three blade mirage may be a good call.
There is a ton of positive trim with this drive like you said perhaps
too much.
Thanks for the info. Im curious on the different bottoms????
If you could post a picture of drives tucked all in from side would be great.
Thanks again bro!
KNOT-RIGHT is offline
Old 10-16-2011 | 08:31 PM
  #82
KNOT-RIGHT's Avatar
Anyone with a Saber single they could shed some light for us.
Maybe some drive heights, props,control issues?
Thanks in advance
Gerry
Old 10-16-2011 | 08:56 PM
  #83
I will check the trim angles and take some pics but it will be a couple days since my boat is in storage. The bottom on 28's was changed after the first 3 or 4. The older bottom has a sharper entry and a little different location of the running strakes. There are some pics somewhere in this forum showing the difference, the newer bottom is more rounded and relocated strakes. It was changed to help the boat turn better from what I was told, but the older bottom cut the chop a little better. Maybe Mike will chime in, he has hull #1, big single.
hotjava66 is offline
Old 10-16-2011 | 09:11 PM
  #84
I think I read somewhere the x on most single 28's was 15 and propshaft depth was appx 6".
Old 10-16-2011 | 09:14 PM
  #85
Older pic of my drives trimmed all the way in on trailer.
Old 10-17-2011 | 09:51 AM
  #86
AIR TIME's Avatar
In my limited experience in testing props, my twin likes bow lift, more the better. I get some porpise at cruise if trimmed out but once I get into the power and get the bow to carry it goes away. Have had best results with 3 blade props, running old school mirage right now. Mine is very responsive to trim, doesnt take much to pick up the bow. Prop shafts are appx 6.5" below corresponding hull bottom. Maybe your drive or drive placement doesnt allow the leverage to carry the bow well? Or is set for too much positive trim? I can check my angles to the transom if it helps, but I know my running range (by eye) is well into negative when buried and only somewhat positive at best speed trim. Trimmed all the way down I get no porpise at any speed, but at low speed any added positive trim will induce a serious propise. I would try a 3 or 4 blade prop if you have an appropriate sized one you can use.
hi it would be great if you could see what degree your transoms at. we checked mine it looks to be 13degrees. this hull ran fine with a b1 drive shortie at 5 1/2'' with a b1 prop. right now with the box my drive is = to 4 3/4'' to 5 '' drive high. it gets right on plane. with a 4 blade it breaks loose. I think its either a wedge is needed or gas tank moved back to center of boat..
AIR TIME is offline
Old 10-17-2011 | 09:59 AM
  #87
wieland77's Avatar
I have the #1 hull and am still in the process of getting things dialed in. Originally my drive was a standard bravo with a deep X of 7 1/2" and running roughly 500hp with a 25 mirage 3 blade I always had a bad porpus when running anything over 4k, would have to heavy tab or tuck drive in to make it stop. I then went up in HP to 750 and running a 28 4 blade it still porpused like a SOB after 42-4300 r's. SO, i changed drives to an XR upper and 2" IMCO shortie lower w/ nosecone and all porpusing went away, maid range to wot. Still looking for a little more bow lift prop and will hopefully be able to get it right next spring. Leaving r's on the table with a 28 4 blade and blowing out a 26 4 blade but bringing the X up to 5 1/2" made all the difference in the world! Doesnt stay as hooked up in the rougher chop like the deep X did but all around a major improvement! Hopefully i can help more if you guys need any other info!! Let me know and good luck Art! Cheers
wieland77 is offline
Old 10-17-2011 | 10:24 AM
  #88
mrv8outboard's Avatar
coolrunning racing
First thing is to check the bottom. Take it off the trailer and get a long straight edge and make sure you know what you have to start. The bottom is what makes it go fast, more horsepower then makes it faster. That being said a bad bottom will run OK with average power, but add more horsepower and it amplifies the problems. Is it porpoising or is it lifting the bow and then falling? One is a bottom issue the other is drive/prop/setup issue? Artie you really should have me put eyes on it.
Jeb
mrv8outboard is offline
Old 10-17-2011 | 10:27 AM
  #89
AIR TIME's Avatar
pics
AIR TIME is offline
Old 10-17-2011 | 10:29 AM
  #90
AIR TIME's Avatar
more
Attached Thumbnails Saber 101-img_7777.jpg   Saber 101-img_7778.jpg   Saber 101-img_7779.jpg
AIR TIME is offline
