Back from the Dead; '81 Scarab 38 Resto
#191
I used 3m panel bonding adhesive (epoxy) to bond the liner and deck together on my 30 footer. It works well. The problem you run into with stringers/transom etc is that the epoxy will grab to poly, but poly won't grab to epoxy. So wherever epoxy is used, poly should not be put back on it. With this in mind, I just go back with poly, it's everywhere else on the boat and is plenty strong.
#192
That is true, I have been using West system 105 resin so it does not give me a problem. Have you had any issues with the bond from the deck to hull on the 30?
#193
Side note - West System epoxy is good stuff, but if you're wanting to save some dough, you can get epoxy for much less $$ from places like USComposites.com
#194
I bonded the liner to the hull, then screwed the deck on. We haven't found anything this stuff won't bond. It's made to hold door skins and roof panels on cars during impacts. If prepped right, it's very good stuff.
#195
We’re starting to get some time to work on the boat. Got back there tonight and prepped the hull to replace the front cockpit bulkhead. Don’t tell anyone but we used a chainsaw to clean out the rotten wood out of the channel. Worked really well, and very fast. I thought I had some wood but all I had was 1/2”. We’ll get back on it Thursday when we have some wood. I set up my laser at the back of the boat and am shooting through the braces and some plastic pieces taped to the braces with holes drilled in them for the laser to pass through. Notice how the original center engine bay stringer is not very straight.
#196
It's kinda funny, one minute you're cutting bits with a chainsaw and the next minute you're lining things up with a laser. One extreme to the other....
Nice to see you've got some time to put in and thanks for posting, I'm sure there's a lot of followers on this thread.
RR
RR
#197
I am following with great respect. What your doing is so much hard work but the end product will make you smile with pride. De rigging my Vioer to bare fiberglass and re rigging was a lot of work but i did not have to do imo the REALLY HARD part fiberglass!!! Thanks for posting progress.
