replacing exhaust hose? >
Old 03-11-2007 | 02:20 PM
Default replacing exhaust hose?
I'm replacing the silent thunder box on my 271fastec with regular tips & mufflers. I removed/destroyed the exhaust hose between the tailpipes & the transom tips. When I go to put the new hoses on, is it easier to do if I take the tailpipes off the exhaust manifolds?? I'm running the EMI thunder exhaust with the stainless riser/tailpipe so if taking the them loose from the manifolds is easier than I need to have some new gaskets sent on the double. Any tips will be greatly apreciated!
cstobe is offline
Old 03-11-2007 | 02:58 PM
You should not need to remove the risers since you will be installing new tips.
Griff is offline
Old 03-11-2007 | 04:09 PM
Too Old's Avatar
Agreed....
Too Old is offline
Old 03-11-2007 | 05:40 PM
offthefront's Avatar
make sure you use the blue soft wall hose ...Alot easier to work with and looks better ... Fred may carry it .... m
offthefront is offline
Old 03-11-2007 | 08:26 PM
Talking
Thanks for the info! I had the EMI exhaust insatlled last winter & they used a heavy duty wire reinfored hose that was a bugger to cut off. I had to use bolt cutters to clip the wire. I ordered new hose with the new tips & it doesn't look to be embedded with wire. Would vasaline be a good choice of lubebricant to slide the new hose up the tailpipes?
cstobe is offline
Old 03-11-2007 | 09:25 PM
I would use a soapy solution if you need to use something.
Griff is offline
AGGRAVATION28
1
03-02-2007 03:44 PM
nordic95
5
04-12-2006 09:35 PM
good2go38
5
12-04-2005 08:51 AM
masi242
5
11-09-2005 09:15 PM
danielthelen
4
05-22-2005 11:30 AM
