What are Baja "Offshore Engine Mounts"? >
Old 10-23-2007 | 04:06 PM
Default What are Baja "Offshore Engine Mounts"?
I noticed in the Baja brochure, that the 26' and up Outlaws have "Offshore Engine Mounts", while the 20 and 23 Outlaws do not. What's the difference between these two mounts? Will the 20 and 23 engines pull out of their mountings if the boats are used offshore?
Michael
Michael1 is offline
Old 10-23-2007 | 04:26 PM
Quinlan's Avatar
I belive it is Thru bolted at the stringer v just lagg bolted into stringer. ?
Quinlan
Quinlan is offline
Old 10-23-2007 | 04:41 PM
The offshore is a plate mount connected to angle aluminum and thru bolted. It is non adjustable. The regular mount is a pedestal type and is adjustable. With regular mounts the adjustment may change with time and abuse but it won't come loose from its mountings.
Jim
MOBILEMERCMAN is offline
Old 10-23-2007 | 08:45 PM
These pedestal mounts are just lag bolted in?
Michael
Michael1 is offline
Old 10-23-2007 | 10:04 PM
Specialized's Avatar
Michael
Yes, but they also have a retaining angle that is thru bolted to the stringer to keep the mounts from just tearing out. but the angle will allow the lag to back out a bit. I think the offshore mounts have been a great addition to what seems to be a brand that is evolving into something a lot better than in the past. Watch out Reggie
John
Specialized is offline
Old 10-24-2007 | 08:22 AM
haulinvols's Avatar
www.Bajaboatowners.com
Baja has long used engine mounts bolted to aluminum L-angles that are through bolted to the stringers. This includes the 20 Outlaw and 23 Outlaw and this design has been used on most performance boats. Just about every review of the boats I have ever read praised Baja for using this tried and true method instead of going to the cheaper less stout design of lag bolting a riser to the stringer such as you would find in a family runabout.
Baja has recently designed a more solid type mount that is utilized on the newer boats they are building. I attached a picture. It it more of a cradle mount and eliminates the adjustable riser mount.
Attached Thumbnails What are Baja "Offshore Engine Mounts"?-motor%2520mounts.jpg
haulinvols is offline
Old 10-24-2007 | 08:37 AM
haulinvols's Avatar
It is not a great shot, but here is part of the 25 Outlaw mount.
Old 10-24-2007 | 08:48 AM
baja bailey's Avatar
So since these types of mounts are not adjustable, I take it that you dont ever have to worry about checking the alignment of the outdrive ??
baja bailey is offline
Old 10-24-2007 | 10:32 AM
Dock Holiday's Avatar
Charter Member #34
You should ALWAYS check the alignment especially if you pull your engines but we have done it twice and the drives were PERFECT with the offshore mounts.
Dock Holiday is offline
Old 10-25-2007 | 10:11 PM
Full Force's Avatar
John
My 86 320 has offshore mounts! been doing it for a while.
Full Force is offline
bobo1
OPA/The Jersey Boyz
0
04-23-2008 07:36 PM
electrical1
11
11-09-2006 08:51 AM
Zanie
3
11-13-2005 04:47 PM
mikesufka
12-26-2002 11:23 AM
puder
4
05-08-2002 01:00 PM
