Go Back  Offshoreonly.com > Owners Forum > Sunsation
Trailer Hitch Ball Size for 32SS >
Old 03-08-2008 | 12:12 PM
Default Trailer Hitch Ball Size for 32SS
I have to go pick my 32 SS MCOB up next weekend, and the guy I'm buying it from, doesn't know the exact size. Is it a
2 5/8 or 2 3/4, does anybody know? I don't even know who makes the trailer, I just have the five letters from the title, which are VANGU. Does anyone know that maker? All help is greatly appreciated
07DominatorSS is offline
Old 03-08-2008 | 12:29 PM
It WILL be a 2 5/16 ball.
Westcoast is offline
Old 03-08-2008 | 01:59 PM
I 2nd that ! If it has an aluimuim trailer you might need a drop hitch. I run mine with an 8" drop turned (UP) on a full size Chevy pick-up. Even with the airbags pumped up and truck leveled out. This is due to the fact that the hyd. brake accuator is on top of the trailer frame.
live wire is offline
Old 03-08-2008 | 03:18 PM
As mentioned, you'll likely need a mild turn up hitch bar on a stock truck to get close to level. I have an aluminum trailer and run a mild drop on my hitch bar, but that is partly because I've replaced my factory hitch on the Chevy with a Putnam XDR and it is now a few inches higher than it used to be.
Make sure that all your towing equipment is rated to handle the load including the hitch ball. The 32SS is likely close to 10k pounds with fuel and gear on the trailer, no less than 9000 for sure. Most factory hitches are NOT rated to tow this much without weight distributing gear, regardless of what the truck is capable of. My 2007 3/4 ton Chevy came with a 7500 LB hitch even though the truck can safely tow upwards of 14k pounds according to the manual.
**Oops, I doubled Sydwayz on some of this advice since we posted at almost the same time**
John
JohnnyG is offline
Old 03-08-2008 | 03:19 PM
Sydwayz's Avatar
Forum Regulator
It sounds like a Vanguard trailer. You will almost definately need a 2 5/16" ball, and your truck's TOW RATING, HITCH, DRAWBAR, and BALL will all need to be rated for 10,000 lbs. with a Weight Carrying hitch setup.
Sydwayz is offline
Old 03-08-2008 | 03:30 PM
Thanks for all the info guys. I drive a 2000 Ford Excursion 7.3 diesel, so towing shouldn't be an issue. I've towed my dads 28 MCOB numerous times, just wasn't sure if it was the same size hitch. You all say at least a 10000lb rating right?
Old 03-08-2008 | 03:39 PM
The 288 is considerably lighter than the 32SS.
Yes I would recommend 10k min rating for the 32SS. The excursion is likely rated for that weight, but double check all of your hitch equipment. You might be surprised what is on there from the factory.
JohnnyG is offline
Old 03-16-2008 | 10:43 PM
Sydwayz's Avatar
Forum Regulator
John
Hey, no worries. I'm ready for a standing post in the Trucks and Trailers forum for "hitch basics".
Sydwayz is offline
tssteph
0
05-17-2004 10:06 AM
ragtop409
05-09-2004 09:07 AM
Ike
05-12-2002 03:51 PM
kook
04-06-2002 04:48 PM
JHR
01-30-2002 09:58 AM
