leaking bravo >
leaking bravo
leaking bravo
Old 08-13-2002 | 10:30 AM
RUSSSR1's Avatar
Default leaking bravo
What is under the top cap of a bravo 1. My port drive started leaking from the top cap last weekend. what would cause this? is it a gasket or is it o-ringed? If oil is comming out does that mean water is going in?
Russ
RUSSSR1 is offline
Old 08-13-2002 | 12:11 PM
blackhawk
Top cap has a large o-ring under it. If oil is coming out there is a chance water could be going in!
http://www.mercruiserparts.com/Show_...%28STANDARD%29
Old 08-13-2002 | 12:17 PM
ursus
There is also an O ring/bushing for the shift shaft under the cap , could be either. Typically the drive gets hot oil expands a little comes out, when drive cools oil contracts and a little water goes in, so it should be attended ASAP
Old 08-13-2002 | 01:12 PM
RUSSSR1's Avatar
If I pull the cap to change the o-rings will my oil bottle drain all over the place. Or should I drain the drive before I pull the cap?
Russ
P.S. It leaks all the time when on the trailer it will leave a couple of teaspoons on the ground over the week.
RUSSSR1 is offline
Old 08-13-2002 | 01:29 PM
ursus
I would pull the bottom drain plug and let a little out into a cup to see if there is any water in the drive. Let the rive sit overnight and water will go to the bottom, check to see if milky etc. If it is you need to drain the drive and change the oil as well anyways . I would probably change it just to be safe .
The bottle will drain but slowly so depends how fast you are
jdub
Drives and Lower Units
2
05-30-2007 08:26 PM
Fboat42
3
10-23-2006 06:32 PM
Fboat42
Prop Talk
2
10-21-2006 06:04 PM
chavvez
7
06-28-2002 09:05 AM
Ike
1
05-29-2002 11:21 PM
