Tomcat-bypass Valve ? >
Old 09-10-2003 | 10:11 AM
liquid lounge
Default Tomcat-bypass Valve ?
Installing bypass valve[s] this eve. Motor is a Gen6 502. You are only using 1 30psi bypass in the hole closest to the crank and you are leaving the the hole that is centered in the pad W/O a bypass, correct? I am leaving everything else stock. Thanks in advance, Berg
Old 09-10-2003 | 10:34 AM
Turbojack's Avatar
Goes in hole on side that is round, with the lip. The other one on the side comes from the oil pump.
Turbojack is offline
Old 09-10-2003 | 10:53 AM
liquid lounge
Wasn't Tomcat advocating omitting the use of the bypass in the hole where the adapter screws on? Thanks for the reply Tjack, but am unable to view attachment.
Old 09-10-2003 | 11:16 AM
Use 30 psi bypass in the round off-center hole. Egg-shaped off-center hole comes from pump. Eliminating the bypass in the center hole eliminates three redundant right turns in the oil supply passage.
tomcat is offline
Old 09-10-2003 | 11:31 AM
liquid lounge
Thanks for the replies- I'll do as told
paulkairis
8
07-27-2007 11:56 AM
Kidnova
27
08-26-2004 01:16 PM
kennyo
6
05-04-2004 10:37 AM
HelmPilot
5
01-30-2003 09:01 PM
traviss
10
06-10-2002 06:16 PM
