Welding Cast Iron >
Welding Cast Iron
Welding Cast Iron
Old 12-08-2003 | 10:07 AM
HOUSTONPROP's Avatar
Default Welding Cast Iron
We have welded several pickups for monster trucks ,usually tig, and stainless.
but if the piece is cast iron the best rod to use on /A/C CURRENT Tig welding procedure is>> a-2 welding rod. which is aluminum/nickle bronze and we have welded several of the Mercruiser exhaust manifolds or anything made of cast iron.
HOUSTONPROP is offline
Old 12-08-2003 | 11:21 AM
Iggy's Avatar
I've welded CI by DC (I think) stick. Can't remember what rod I used (too many years ago), but I do remember that it was a special rod.
I know you should preheat the material to several hundred degrees prior to welding to prevent thermal shock. Then stopping every so often to reheat the material and allow a slow cool down at completion.
CI gets very brittle during the welding process. If not done correctly it will fracture along side of the welded area.
Sounds like you've got a good welder working for you.
Good job.
Iggy is offline
Old 12-08-2003 | 11:31 AM
cougarman's Avatar
Default Cast Iron
I believe preheat and weld with nickle Rod.
cougarman is offline
Old 12-08-2003 | 01:43 PM
Iggy's Avatar
CougarMan I think you're right.
The use of a nickle rod sounds familiar.
Thanks for jogging the memory.
Iggy is offline
Old 12-08-2003 | 03:09 PM
nickle/aluminum a-2 welding rod
Pantera24
08-05-2007 08:09 PM
berman58
01-12-2006 07:47 AM
9Hound
9
07-22-2005 02:40 PM
AGGRAVATION28
5
01-11-2005 08:24 PM
jeffg
9
05-07-2003 07:46 PM
