Where is the water coming from??????
Any ideas where water might be leaking into the bildge at??
I have checked the plug seal and it is good. I had my drive serviced recently and it seems to have started after that. I noticed when the mechanic put the drive back on (regular bravo 1) he just stuck it on and bolted it in... I'm sure he knows what he is doing but how does that seal? And should it be sealed.
THANKS!!
THANKS!!
I had a leak around one of my drive trim indicators. Drove me nuts until I found it. Had to almost crawl under the engine to see a small stream down the inside of the transom. Pulled the flange, cleaned the surfaces, let it dry, then applied marine sealant and re-secured.
