Bottom Coat? >
Bottom Coat?
Bottom Coat?
Old 12-20-2004 | 08:24 PM
Question Bottom Coat?
Another question for you guys: When I power washed my boat this past season the gelcoat chipped (under waterline). It had fine cracks to start with. It's a 86 357. Should I paint the bottom with something? I had it surveyed at the beginning of last season and the hull seemed fine. The small cracking was there but didn't seem to be a problem.
johnkot is offline
Old 12-21-2004 | 06:40 AM
Formula Outlaw's Avatar
Default Re: Bottom Coat?
The small cracks are probably just stress cracks on the gelcoat, look carefully and you should be able to tell if it's "blistered" or not, a much worse problem.
Don't paint. Just regelcoat it.
Formula Outlaw is offline
Old 12-21-2004 | 06:04 PM
Thank you. Is regelcoating a big process? Do you mean just the chips or entire bottom? I leave the boat in a slip all season. It's in fresh water so it only gets slimy but no barnicles. It does not look like blistering but there may be a couple small ones. How much do you think it would cost to have it regelcoated?
JK
johnkot is offline
Old 12-27-2004 | 08:22 AM
Use a product called VC Epoxy, Its teflon based it protects against blistering and is so easy to clean at the end of the season. Especially if you are leaving your boat in the water for extended periods of time.
As far as cost a kit which includes 1 gallon of paint and 1 gallon of activator should run you about 100 to 150 bucks.
I put this stuff on my Baja 320, and I love it the boat picked up a little bit of speed and most of all it is white unlike most other bottom paints. And with it being teflon based nothing will stick to it. Spray it off and your done!!!!!!!!!!!1
fleg1 is offline
Old 12-27-2004 | 08:52 AM
bob
Charter Member #40
Fleg1, VC sounds interesting. What type of primer did you use? Does it seem as durable as other epoxy paints?
bob is offline
Old 12-27-2004 | 05:08 PM
Red face Re: Bottom Coat?
Fleg1: I like that idea, sounds simple enough. How long does it last? Is this an annual event to repain with this VC Epoxy? Any prep required besides cleaning?
Thank you
JK
johnkot is offline
Chris288
Detailing, Painting, & Fiberglass
7
09-20-2007 04:31 PM
jayhawk261
10
04-02-2007 03:30 PM
Fenderjack
14
02-14-2007 07:22 PM
pb
7
08-24-2005 01:19 AM
Pantera1
07-21-2002 10:18 PM
