Ford integrated brake controller >
Old 09-04-2006 | 08:59 AM
BillR's Avatar
OSO Moderator
Default Re: Ford integrated brake controller
I use mine w/ Myco Elec over hyd and it works fine, I just get a annoying beep and a message saying the trailer is disconnected. But it works and stops just fine.
BillR
'00 Scarab Sport 302 CC
'02 Cigarette Top Gun TS
'02 PQ 340
'00 PQ 280
'98 Scarab 22
'97 Baja Outlaw 20
'72 Checkmate
'65 Glastron
BillR is offline
Old 09-04-2006 | 09:40 AM
Brake rite system is compatible with Tow Command. Plug it in and go. Tow Command is really the best. I would just change the hydraulic pump instead of all the adaptors and stuff. I tow a 382 and it works great.
382 newbie is offline
Old 09-05-2006 | 12:44 AM
Originally Posted by horsplay
thanks ,im actually getting that fixed now, i had alot of play ,while your driving trailer would go back and forth like a pendulum , very annoying, did that cure your problem?
I just had to shim the ajustable neck part of the trailer, it had about a half inch of foward to back play. It wouldn't do it all the time just when you had to brake hard or when you took off from a stop then slammed on the brakes. It was so bad that it would throw you out of your seat in a f350 dually. Are you pulling with a regular hitch or gooseneck/5thwheel?
steve1k99 is offline
Old 09-05-2006 | 07:41 AM
horsplay's Avatar
trailer is a gooseneck , what you just said is exactly what is happening to mine, it would jerk back and forth so bad , that you could not even see, getting that fixed now thanx
horsplay is offline
Old 09-05-2006 | 03:17 PM
At least you now know your hitch won't break if it can handle that. Another thing I did to my 5thwheel was bring up about 1-2inches higher. It seems to tow better but its hard to tell since I am using a different truck. Good Luck
Old 04-02-2008 | 08:59 AM
rjr
I called Carlisle. They told me that their controller does not work with the 08 Ford controller.
rjr is offline
Old 04-02-2008 | 10:08 AM
I have a 03 myco with electric over hyd. & pulled with a 06 F-250, 08 F-350, & now have a 08 F-450 & none of them will work the brake system.
allfiredup is offline
Old 04-02-2008 | 03:39 PM
rjr
Allfiredup.. What actuators have you tried with the Tow Command. Carlisle told me that the problen is with the 08's not earlier models. Dexter said theirs works but may send false warning messages
rjr is offline
Old 04-02-2008 | 10:07 PM
I have an 08 f350 and the tow command didn't work with my trailer. Carlisle has no fix last time I talked to them. They have the fix for prior years though. I had the local trailer shop put my other controller in and run a new wire to the plug in the back. Wouldn't buy IBC if I did it over again.
bajasst is offline
Yamaha 225
18
09-08-2008 11:48 AM
bjablonski
7
04-26-2008 09:57 AM
rjr
2
04-02-2008 10:23 AM
duksrule
4
07-03-2006 12:40 AM
J.B. Marshall
0
05-15-2006 05:03 PM
