heavy towing with f450
#102
the hitch is the factory unit -- pretty beefy.
#107
is the pintle hook welded to a solid steel shaft to insert into the receiver so that you can use the receiver for trailers other than the pintle? Do you use torsion or anti sway bars with the pintle system or dont you need them?
#108
yes - you can remove it and no i havent needed any anti sway bars.
