heavy towing with f450
Old 09-01-2007 | 10:33 AM
Registered User
Originally Posted by pookie
... that a 3000 pound Yugo....
3000 lbs?
That's a lotta' Yugo.
Chris Sunkin is offline
Old 09-01-2007 | 10:49 AM
That allows weight for me and three fat chicks to take with me boating.
pookie is offline
Old 09-01-2007 | 11:02 AM
I had a problem last weekend towing the race boat to long island. First time i towed with the truck. The boat kept swayying going down the road. Boat was full of fuel. And have towed the boat behind a bunch of different ford trucks. And never this problem. Now coming home the boat towed good with an empty tank. What could it be?
BobbyB is offline
Old 09-01-2007 | 11:25 AM
Registered User
Worn steering components,
too little toe-in on front end,
Too little air in tires (or maybe too much)
Wrong tires (are they stock?)
Lifted truck?
You clearly have a weight distribution problem. Likely it's too little tongue weight. That's aggreavating whatever is wrong with the truck. Sometimes you'll get sway with too much tongue weight but it's got to be extreme. Some trucks are more sensitive to rear squat than others (squat causes changes to your front end's steering geometry, moreso on IFS trucks)
Old 09-01-2007 | 11:31 AM
Registered User
Yugo's about 1,700. You'd have to take all four.
Is the 4th riding in the middle of the back seat or in the hatch?
Old 09-01-2007 | 11:58 AM
Lifted truck?
Its a brand new 2008 F450. Had 750miles when i left the house.
BobbyB is offline
Old 09-01-2007 | 02:23 PM
the little one on the right could ride in my lap!
pookie is offline
How much does that race boat weigh?
pookie is offline
Old 09-01-2007 | 03:36 PM
Registered User
If you've towed it with similar vehicles in the past and not had any problems, you wouldn't think a truck as robust as the 450 would have much sensitivity to heavy tongue weight. Still, that's pretty much going to have to be the root of the problem if the issue goes away with light tanks- unless you're pulling a raceboat with saddles in the back.
is it squatting much when you drop the tongue onto the hitch ball? 2wd or 4wd?
Old 09-01-2007 | 03:39 PM
purnell's Avatar
Thumbs up
i like mine
purnell is offline
