duramax or power stroke?
Old 02-14-2008 | 10:45 AM
czy40p's Avatar
May 2007 quote: If buying trends say anything here is a few votes for the Dmax.
Buttermore said GM's market share of heavy-duty diesel pickup trucks in North America has grown from 3 percent in 2001 to nearly 30 percent with the introduction of the Duramax diesel.
John Buttermore, vice president, GM Powertrain Global Manufacturing
http://www.autobloggreen.com/2007/05...ax-diesel-v-8/
czy40p is offline
Old 02-14-2008 | 11:00 AM
I wouldn't be such a proponent for the duramax if I felt the trucks were all similarly matched. It would be much easier if they were. In reality, the duramax is a whole leap ahead of ford and even the mighty cummins.
Joe92GT is offline
Old 02-14-2008 | 04:02 PM
hp500efi's Avatar
Member #9
I love my 06 DMAX and it is fully stock. I had to Chip my PSD and it still was not as powerful as the stock DMAX. The 6SPD is huge when towing. Being able to drop down to 5th for whatever reason is a great advantage.
Member of the Liquid Jungle
hp500efi is offline
Old 02-14-2008 | 05:18 PM
Originally Posted by kennyo
Didn't you read the part about being retarded.....
Must have missed that part
Bottomfeeder is offline
Old 02-14-2008 | 05:30 PM
I have to agree on the DODGE. That is the only bad thing about my truck, the POS wrapped around the motor.
PJDiesel is offline
The bolt pattern on the chevy is only 8 on 165mm. The Fords are 8 on 200mm on the F350s. That should tell you something Ford has a much stronger body, frame, and suspension.and still rides better. Handles heavy loads better, always has and always will. You chevys guys know it deep down inside. 340 plus diesel hp is enough to pull anything you need to pull anyway.
BDARCHER is offline
Old 02-14-2008 | 05:37 PM
PJDIESEL sweet looking Dodge with the 24 inch wheels. Still the best looking body.
BDARCHER is offline
Old 02-14-2008 | 05:55 PM
Yes, you are absolutely right. Now, all ford needs to do is find a good diesel engine. Until then, chevy wins with the duramax. Put the duramax or cummins in the ford, and you have the best truck ever made.
Joe92GT is offline
Old 02-14-2008 | 06:21 PM
FASTTIMES's Avatar
Funny you say that, I have been checking out some Ford SD forum's and there are guys putting cummins in the F250s.. Seems like alot of damn work
FASTTIMES is offline
Old 02-14-2008 | 07:59 PM
I have a completely stock 2008 f450 with a 4.88 rearend. It is the only one ton that legally tows my boat (or even comes close). I have about 6000 miles miles on it and get just over 12 mpg (not towing) with everyday driving. It is quiet and smooth and has enough power to pull uphill. A friend of mine tried to tow my boat with his 2006 Duramax with a Bullydog chip, aftermarket intake and exhaust and oversize wheels and tires. He lost significant speed on a relatively shallow hill and barely made it up coming away from the lake. Also, that thing is way too loud!
fountain 47 sc is offline
