Trailer Bunk Question
Old 04-28-2008 | 02:55 PM
Love Machine's Avatar
Default Trailer Bunk Question
I'm replacing some guide bunks on my South Florida Trailer and was wondering if they should be bearing any of the boat weight. As you can see from these pics it is. I don't think they should. What are your opinions?
Attached Thumbnails Trailer Bunk Question-img00093.jpg   Trailer Bunk Question-img00094.jpg
Love Machine is offline
Old 04-28-2008 | 03:19 PM
Registered User
Take them out and replace them with dual V-rollers at each crossing brace. The bunks that contact the chines are what needs to be doing the work. They're right under the stringer so you're bottom won't deform sitting there. Sitting on the vee is asking for major hook.
You need the rollers for trailer loading at the ramp. You probably don't want to gouge the bottom on those crossrails.
Looking at your pics, I'm not in love with those bunk pedestals either. One crossbolt is all that's holding them up. There should be box tubing vertcally up into a u-shaped pad that the bunk will nest into. They need to be a little taller too- looking at the pad between those v-bunks, it looks like the keel has been scraping.
Chris Sunkin is offline
Old 04-30-2008 | 10:24 AM
Would rollers help on a Myco tandem dually? I love the trailer and the bunks support the hull very well but it has solid axels and the boat sits high. It's a big boat so on some ramps I can't get it deep enough to float off. Powering on and off on a smaller ramp is sometimes a chore. Wondering if adding rollers would be advisable.
fountain 47 sc is offline
heaterman
11-27-2006 09:38 AM
Gene in NC
08-17-2006 09:56 PM
fatdaddy
10-15-2003 08:56 PM
WETTE VETTE
15
12-30-2002 03:23 PM
Chart
22
04-05-2002 04:02 PM
