What Do I Do With This 2008 F450? >
Old 09-02-2009 | 05:49 PM
  #221
Originally Posted by Jassman
Originally Posted by CGiron
An official relese from Ford might be found here.
http://www.autoblog.com/2009/08/31/b...-new-6-7-liter
" First use of a compacted graphite iron (CGI) engine block in a Super Duty-class vehicle in North America; stronger than regular gray cast iron, Ford has successfully used CGI in engine blocks in products around the world. The block structure was optimized for reduced weight and maximum strength to meet the demands of higher torque and horsepower"
Ford diesel tries, quietly, to silence predecessor's quality issue
Richard Truett
Automotive News
August 31, 2009 - 12:01 am ET
DETROIT -- The first thing you notice about Ford Motor Co.'s new 6.7-liter Power Stroke diesel truck engine is how quiet it is. Standing next to it, you wouldn't know it was a diesel unless someone said so.
The engine debuts early next year in Ford's revamped line of Super Duty pickups. Ford won't talk about horsepower and torque until the Texas State Fair on Sept. 24. But auto writers recently got a preview.
The engine is important. Ford lost customers because of quality problems with the current diesel, which is supplied by International Truck and Engine Corp. Ford produces the new diesel itself.
Ford's new diesel
Ford's new 6.7-liter Power Stroke diesel V-8
-- Optional on revamped Super Duty pickups early next year
-- Designed, developed and built by Ford
-- Weighs 160 lbs. less than the current engine supplied by International Truck and Engine Corp.
-- Features 4-valve-per-cylinder aluminum heads, piezo fuel injectors and an advanced turbocharger
-- Cuts emissions of oxides of nitrogen with a urea injection system
Ford engineers designed the new Power Stroke with various innovations:
-- Fast-acting piezo fuel injectors supplied by Bosch deliver as many as five shots of fuel per piston stroke. This nearly eliminates the familiar diesel clatter, improves performance and cuts emissions.
-- Aluminum cylinder heads with inward-facing exhaust ports reduce noise.
-- A single, sequential turbocharger with twin impellers delivers performance at low and high engine speeds, reducing turbo lag. The turbocharger, made by Honeywell, is mounted in the "V" between the cylinder heads.
-- A block made of lightweight compact graphite iron helps cut 160 pounds of weight compared with the outgoing 6.4-liter International diesel block. Ford buys the block from Tupy SA, of Brazil.
-- A urea injection system, also from Bosch, helps neutralize emissions of oxides of nitrogen. It's the first Detroit 3 engine to use urea. The chemical will be available at Ford dealerships, truck stops and auto parts stores. The urea tank must be refilled every 7,500 miles.
The engine is designed to last 300,000 miles without major service, says Adam Gryglak, the Power Stroke's lead engineer.
It has been in development for four years. It will be built in Chihuahua, Mexico.
The diesel is one of Ford's most expensive options. The current base F-250 Super Duty starts at $26,275 including delivery. The diesel engine package adds $9,325, which includes a bigger engine cooling system, a stronger transmission and bigger brakes.
Ford says 60 percent of Super Duty F-series pickups are sold with Power Stroke engines, or about 175,000 units last year.
I read about that 'compacted graphite iron' block. Sounds promising. I've heard estimates of 400hp/750tq from that motor. The problem is it's the same size as the 6.4 which is HUGE, causing the cab to have to be lifted off the frame for service. For occasional haulers like boaters it might be the solution to the Navistar problems.
For those of us who care about these issues, this article is depressing. America has lost over 50,000 manufacturing companies in the last ten years;
http://www.cleveland.com/business/in...esel_truc.html
My truck(2006 Dodge dually) is built in Mexico too so I guess I shouldn't complain too much.
Catmando is offline
Old 09-02-2009 | 06:01 PM
  #222
Default ford f450 is crap
call me i will give you the name of my attorney needs 3 or 4 more trucks to do a class action lawsuit i have already filed for a court date hearing ford is not going to resolve anything unless you file a lawsuit and go to trial beleive me my number is 786-301-3767 BIG AL
al cerda is offline
Old 09-05-2009 | 06:51 AM
  #223
Chuck's Avatar
Well it looks like I'm getting bent over once again. I think that the BBB is run like a state run organization. Not one person seems to have a real grasp of what the policies are, or are not. After follow up calls(on my part) to check on my first week of Sept. arbitration hearing I was told that we are just waiting on an arbitrator in my area and it will now be around mid Sept. Then yesterday I receive an e-mail apolagizing for the miscommunication but the only thing I am eligible for is repairs (well no chit, the truck is still under warranty), but that a Ford engineer is willing to sit down with me and inspect the vehicle. I'm sure in a couple of days I will get another e-mail stating that the engineer will inspect the truck but not speak to me about it. I'm giving up on this free chit and need to decide whether to hire an attorney or just place my head in the sand and take it in the ass.
Chuck is offline
Old 09-05-2009 | 10:45 AM
  #224
I finally got rid of my 08 F-450 fuel HOG. After breaking down on me with only 5600 miles I traded the sucker for a new 4x4 Duramax Chevy. Out of 6 Fords I have had only two good ones, both were 7.3s. 3 were 6.0s, turbo issues and the last one the 450. NEVER AGAIN WILL I STOOP SO LOW TO BUY A FORD.
Roger is offline
Old 09-05-2009 | 07:28 PM
  #225
Duramax/Allison is a proven powertrain. If you're not a member already you should join the GM diesel forum.
Catmando is offline
Old 09-06-2009 | 12:21 PM
  #226
2112's Avatar
the Isuzu/Allison combo has it's share of problems, don't bury your head in the sand. Cummins? yeah, the 5.9 is reliable but you have to tolerate poorly built chassis and body to get it.
2112 is offline
Old 09-08-2009 | 01:08 AM
  #227
Like I said in another thread, the Allison will fail if pushed beyond 100hp engine mods. The Duramax has gone through several updates, all of them better than either the Navistar 6.0 or the 6.4.
Maybe I'm just lucky, but I have yet to have a problem with the chassis or body on my Dodge dually and I've got just over 62,000 miles on it. In fact my only gripe has been the POS cabin vent design. The little vertical slides are gnarly and those things that move the vanes from side to side are VERY hard to move. I hope the new trucks don't have those problems.
I'm going to the State Fair in Dallas this month and I'll check for sure. I want to drive the 2010 so bad I can taste it.
Catmando is offline
Old 09-19-2009 | 03:46 AM
  #228
Pull the motor and put a Cummins in it, then you'll have a truck, sorry couldn't resist. Thats why my 2 fords have cummins in them now. To many problem with the powerstrokes. I have 2 fords and 2 dodges all with cummins in them. JD
jdscj8 is offline
Old 09-19-2009 | 03:25 PM
  #229
I have to agree with that^^^. So do these guys;
www.fordcummins.com
Catmando is offline
Old 09-20-2009 | 11:53 AM
  #230
The 7.3 powerstroke is bar none the best ever, 400,000 miles problem free other than a cam senser now and then. my 03 7.3 with edge in it with over 100k is a awsome set up im spining 37s with 6" lift crew cab long bed, gets 19 mpg and 16 towing the 10000 pound boat and trailer,, and tows it with ease.
rssteiny is offline
