Oil Change Interval on Diesels
Old 03-05-2011 | 06:51 PM
  #41
seafordguy's Avatar
Originally Posted by 07DominatorSS
What happens is Petroleum products over time can create "false" seals, aka buildup, and with the high detergent packages in the synthetics, those can start to be cleaned up and yes, may "open" up some leaks. So there is some truth to your statement.
Yeah - that is EXACTLY what I have read over the years, and mirrors my experience....
seafordguy is offline
Old 03-12-2011 | 09:25 AM
  #42
Originally Posted by vette131
EGR & DPF systems are mostly separate from each other. EGR is used to cool cylinder temps to reduce oxides of nitrogen production. The DPF system with or without urea is is used to reduce particulates in the exhaust. both systems are strictly used to please the tree hugger crowd & both lower your mpg especially the DPF.
I just bought a 2010 F450 with the 6.4, truck is completely stock.
What should I be looking at doing to the truck, DPF delete with a tuner?
Anyhting else I should do to make it a trouble free ride??
Thanks,
mike
verbi69 is offline
Old 03-12-2011 | 10:41 PM
  #43
vette131's Avatar
Thanks,
mike
see post 39 verbi nice truck!
vette131 is offline
Old 03-13-2011 | 10:35 AM
  #44
05 6l ford 4000 miles.
mike tkach is offline
Old 03-13-2011 | 10:40 AM
  #45
Right on, thanks Vette.
verbi69 is offline
Old 03-13-2011 | 10:47 AM
  #46
Vette,
I sent you pm, not sure if it went through though.
Where is the best spot to put the small micron fuel filter, and what type of filter.
Can you get the dpf, egr delete kit from one source, and what's the best tune.
Sorry to highjack.
verbi69 is offline
Old 03-13-2011 | 10:56 AM
  #47
BUIZILLA's Avatar
instigator
every 5,000 or 125 hours, whichever is first
or 400 miles for every qt. of oil capacity... max
BUIZILLA is offline
Old 03-13-2011 | 11:02 AM
  #48
I have a 07 Ford F 350 diesel dually, we tow our 38 ft Cigarette from Nj. To FlA, every winter, so we change our oil every trip which is about 3,000 miles, I use Motorcraft oil, the truck has 40,000 miles on it, it has never burned a qt of oil
Top Ven is offline
Old 03-13-2011 | 11:18 AM
  #49
Thanks,
mike
So
Old 03-13-2011 | 05:35 PM
  #50
Originally Posted by RunninHotRacing163.1
So
I guess I should of asked you how high of a lift to put on instead...lol
verbi69 is offline
