Anemic 383 SBC >
Anemic 383 SBC
Anemic 383 SBC
Old 06-21-2022 | 07:43 AM
Wait...you are expecting 450/500 hp when the motor is redone, and. your wonder why it currently doesnt want to spin a 25p prop to 5500 rpm now. You also state your seeing 68mph now.. Having a 22 foot 24 degree boat myself, that sounds about spot on for a small block making 350-400hp now. With a 330 I saw 60, with 650 and a raised X I have seen 83 Your expectations may be a bit out of alignment.
phragle is offline
Old 06-21-2022 | 09:03 AM
I guess we will all find out next season. I haven’t had this boat very long. I’ve been out of boating since the early 90s so I’m feeling my way back in to the boating scene. Im speaking to some very knowledgeable people to help me along with this project. I’m not much will projections so I’ll just wait and see what the new combination does on the dyno and how the boat reacts once the new power is installed. Thanks for your opinion and we shall see how close you are next year when the boat comes back out.
Donnie D is offline
Old 06-21-2022 | 10:09 AM
My 21' Hammond Challenger was similar to your 22. Both pad bottom light hulls.
My 385ci
AFR 190R heads 10-1 static
Cam Motion 234/240 .580/.568 112+4
Portmatched RPM Airgap
Dry to transom exhaust
Holley 750HP
475-500hp estimated
Ran 77-78 anytime. 79-80.5 best conditions
5800-6100rpms. Labbed 22p Hydro QIV
That cam is rather small IMO for your goals.
Ryan00TJ is offline
Old 06-21-2022 | 10:35 AM
What gas do you run in that boat? Tony Bischoff wants the new engine to end up with 10-1 compression. He also stated that the cam we are planning on using was a little aggressive, but would be a good choice. Honestly I don't have any etched in stone goals other than for the boat to be reliable and not be a complete and total pig. Other than that I just want something my wife and I can go out and have fun in. It will never be an off shore boat, and it will never be a 80 MPH plus boat as it will only see lake and river use. It won't be continuously romped on. Just a blast across the lake or down the river from time to time. I really want to bring this boat back to what it once was with the only difference is for it to run much better than it did when delivered with it's 260HP Mercruiser power which I've been told by the original owner the boat ran 66 MPH with that combination. If the boat will run 70-75 MPH honestly...I'll be happy with that.
Donnie D is offline
Old 06-21-2022 | 12:33 PM
Just keep in the back of your mind, things that are nothing in a 22' boat at 60 start to be rather intersting at 70, by the time you get to 80, interesting can become puckering really fast. But it is fun flying by some bigger "fast" boats....
phragle is offline
Old 06-21-2022 | 01:27 PM
SB
Originally Posted by Donnie D
we are shooting for a 450-500 HP range and I'm expecting a realistic 475HP out of this combination.
This is what's needed below. You'll need 230* at .050" or more to get 475-500hp.
As a note: 218 at .050" flatlines (HP stays flat) in power around 5200rpm in a 350. 5k in a 383. Many builds and small single engine boats with decent heads show this
My 385ci
Holley 750HP
475-500hp estimated
SB is offline
Old 06-21-2022 | 02:31 PM
This is not my first Velocity or fast boat. I've had a 23 and a 30. I also was an operator of the Cincinnati Fire Department Fire/Rescue boat. Though I've been out of boating for a while. I grew up boating on the Ohio River.
Donnie D is offline
Old 06-21-2022 | 08:07 PM
The plan for the engine is to have the Sporstman II heads massaged by BES. Remove the Team G intake and replace it with a Edelbrock Performer RPM Airgap. A Holley 750 CFM dual line double pump carburetor. The comp cam that is currently in the boat is the one on the cam card in the posted photo. The cam going in the engine specs are as follows with a 1.6 rocker arm. 576/555 I/E, 271/297 adv dur. and 216/223 @.050. 106/118 centers and a 112 LSA. I'm not sure what the pistons are or what the current CR is. As stated the engine is supposed to have a Callies internally balanced crank and Eaglt H beam rods. All parts will be approved by Tony Bischoff before it goes in the engine but we are shooting for a 450-500 HP range and I'm expecting a realistic 475HP out of this combination.
unlikely with those heads, a baby cam, and boat exhaust. The mystery compression ratio is a concern too
hogie roll is offline
Old 06-22-2022 | 12:23 AM
Marina 89 fuel. FR2lS plugs and 78/88 carb jetting. Bischoff is being conservative on the cam specs. You would need to modify your exhaust to go much bigher than his cam spec.
Ryan00TJ is offline
Old 06-22-2022 | 09:08 AM
My 18 foot Baron is a 58mph boat with a 260 merc, I have ran with a lot of stock Merc 260 boats in the past, 18 Donzis and 21Scarabs back in the day.
All were about dead even for speed at 58mph..
Back when we built them we spent a day with Mercury and a trailer full of props and a radar gun trying to figure why the 280/trs boat was so much slower than the other ones we built that were 260/Pre alpha Mr drives.
260/mr boat 58 on radar.
280/Trs boat 55 on radar.
I think your 66mph with a stock 260 merc was a optimistic Tale.
tommymonza is offline
