imco shortie >
imco shortie
imco shortie
Old 03-19-2005 | 07:13 PM
  #51
Dock Holiday's Avatar
Charter Member #34
Default Re: imco shortie
Okay, here they are.
The first shot is two days before we pulled them out of the boat last December.
Second shot is last week, the Starboard engine is back in the boat.
Third picture is the Port engines ready to go back in. Actually it is in the boat now.
We are waiting on the new tail pipes from CMI which should be here next week, then we can put some props on her and see what happens.
The motors look completely stock. The changes we made we all internal.
Attached Thumbnails imco shortie-dsc03192.jpg   imco shortie-dsc04479.jpg   imco shortie-dsc04500.jpg
Dock Holiday is offline
Old 03-19-2005 | 07:29 PM
  #52
baja36ft's Avatar
Looks Great Dock Keep Me Posted On The Results!!!!
baja36ft is offline
Old 03-19-2005 | 08:06 PM
  #53
crayolacrazy's Avatar
Originally Posted by garshev
CRAYOLACRAZY, How does your 33 ride and handle at those high speeds?? Just curious what would happen if i whippled my 500's.
The boat runs smooth. I would not think twice. Whipple's kits are proven. I think you will make another 250 hp. Dustin Whipple dailed my boat in by phone. How long is your boat? I'm putting together some long blocks as per whipples specs that should make close to 800hp. We are copying a rebuild that whipple has allready done. Dustin picked the cam and will reprogram the ecu. I have 354 hrs on the motors now. My motors are still strong. My compression is still 160-165 . KEEP IT COOL, RUN GOOD FUEL... you will be fine.
crayolacrazy is offline
Old 03-19-2005 | 08:13 PM
  #54
Hey Doc lookin good just to let you know I have 28 29p5x 30 32 all labbed except 29 p5x .I also have 1/2 ,1 ,1-1/2 spacers
Old 03-20-2005 | 05:42 PM
  #55
Originally Posted by baja36ft
Sorry nothing new yet i took the motors out and did alittle
work.they are going back in next week.
.........What kind of "work" ?
JaayTeee is offline
Old 04-01-2005 | 07:12 PM
  #56
baja36ft's Avatar
Well, The Motors Are Back In And It's Time To Prop Test Maybe On Sunday!!!!!!!!!!
baja36ft is offline
Old 04-11-2005 | 08:02 PM
  #57
baja36ft's Avatar
Well,went out on sunday with a set of 30 pitch bravo's turned
them 5100 but no speed 72mph (whats that a 22% slip)
not good julie does not think the 5 blades are going to help
me or a 1/2 inch spacer she thinks i should put the old
units back on and try that.there is no hook in the bottom
of the boat so i really don't know what to think!!!!!!!
baja36ft is offline
Old 04-11-2005 | 08:34 PM
  #58
Charter Member #34
Baja, you are having the same bad luck a buddy of mine is having with his 31 Bullet.
He has some blower motors putting out 800 HP per side and the bullet has hit a top speed of 86 on the GPS with standard Bravo drives.
He has had a lot of drive problems lately and got a chance to try before he buys, a couple of IMCO shorties.
At first he could NOT get the boat on plane. Then he borrowed some 5 blades and reversed the rotation and managed to get on plane and make it through a poker run.
I spoke to him last Thursday and he has played with several props and the best speed he can get is 75 MPH. He has lost over 10 MPH.
We have concluded that true deep vees are not good candidates for the shorties. He is going to pass on the IMCO's and go with some standard XR's.
Guess you better get them spaced back to normal. Very sorry to hear this, I was hoping they were going to work well and show some performance increases.
Thanks for keeping us up to date.
Doc
Old 04-11-2005 | 08:47 PM
  #59
baja36ft's Avatar
Thanks DOCK, i was looking for something out of them.
Did you get to run you'r boat? any speed change?
I am putting back on the bravo lowers and going out this weekend and try it again!!!!!!
baja36ft is offline
Old 04-11-2005 | 08:57 PM
  #60
Charter Member #34
Ran the boat Friday in Jacksonville and yesterday here on Lake Norman.
The boat is running very good, but have only been able to run it with my 26 pitch props. I have some 28's being shipped up to me from a buddy in Jacksonville to try next week, and I also hope to fine a pair of 30's to try also.
She is definately under proped at this point! The mid range is awesome and we sill see what happens with the top end when I get the props in.
Will keep you posted.
