imco shortie >
imco shortie
imco shortie
Old 04-12-2005 | 09:01 AM
  #61
JasonSmith's Avatar
Default Re: imco shortie
The 29 OL I just bought has 1" shorties with 454 mpis, labbed 26 4 blades . I have seen 73 with it and it does blow out comming on plane. Other than that I am happy with them.
JasonSmith is offline
Old 04-12-2005 | 09:37 AM
  #62
BajaRunner's Avatar
are those mags (385hp) or mpis (310hp)?
BajaRunner is offline
Old 04-12-2005 | 12:16 PM
  #63
JasonSmith's Avatar
mags
Old 04-14-2005 | 05:45 PM
  #64
baja36ft's Avatar
Can Someone With A 1999 /2000 36 Outlaw Measure
The Bottom Of The Transom To The Bottom Of The Hull And Let Me Know What It Is!!!!!!!!!! Maybe Doc?
Thanks!!!!!!!
baja36ft is offline
Old 04-14-2005 | 08:02 PM
  #65
Dock Holiday's Avatar
Charter Member #34
Thanks!!!!!!!
I will be glad to and can do it tonight, but I'm not sure I understand what dimension you are asking for?
Do you mean the very bottom of the vee in the center of the transom up to where the bottom starts to get flat?
Let me know.
Doc
Dock Holiday is offline
Old 04-14-2005 | 08:29 PM
  #66
yzbert's Avatar
i will this weekend too if you let me know where
yzbert is offline
Old 04-14-2005 | 09:10 PM
  #67
Charter Member #34
Thanks!!!!!!!
From the very bottom center (under drain plug) up to where the vee ends and the hull is flat measures 11.55 inches on my 2002 model.
If this is not what you are looking for, please let me know.
I measured from the floor up to each point and took the difference to be accurate.
Old 04-14-2005 | 09:12 PM
  #68
Charter Member #34
It's only cold three quarters of year up here !!!!!
I would be moving SOUTH Buddy!!!!!!!!!!!!
Old 04-15-2005 | 05:48 AM
  #69
yzbert's Avatar
yeah i know but are three months are really nice
yzbert is offline
Old 04-15-2005 | 01:54 PM
  #70
baja36ft's Avatar
I am looking for the drive hieght I thought it would be easy
to get it from under the transom to the bottom of the boat.
it should be around 5 to 6 inches do it from the back of the boat under the transom!!!!!!!! thanks.
baja36ft is offline
