Cafe Racer Refurb (Hull #69) >
Old 06-29-2020 | 10:04 PM
  #31
Default Cabin Door Latch Receiver
Originally Posted by 1Zoom
If this is the part you are looking for I will take measurements and closer photos. Let me know.
That's the part. If it would have been just flat it would have been easy to fab up.
DealmakerC6 is offline
Old 06-29-2020 | 10:23 PM
  #32
I am sure I can mill one, if you are willing to wait a bit. I have been very busy trying to get mine ready as well. I had it in the water two days ago to test things out and found the steering was binding. Now I'm in the middle of changing it. Hopefully I will be able to catch up in a couple of weeks. If you are going to LOTO at the end of Aug. I should be there and probably can have one made up for you. Let me know.
If not I will take some measurements when I get some time and post them for you.
1Zoom is offline
Old 06-30-2020 | 12:15 AM
  #33
1Zoom: I am good with waiting! I have no other options either, so that does make it easier
My email is in one of the above posts, but it is [email protected] and if you could email me contact info, that would be great.
I will say that if I think I can pull off SeafordGuy's idea I would prefer that, although I still would want the ability to hard-lock the cabin door.
Old 06-30-2020 | 08:51 PM
  #34
Did you pull the port console out? If so how much of a pain was it, I was thinking of pulling mine out and making new Delrin rollers for my door. It works but I would like it smoother.
1Zoom is offline
Old 07-05-2020 | 01:35 AM
  #35
I haven't pulled the port side dash yet. I am going to have to pull it at least by the end of the season, for the new stereo install. I am also planning to pull the cockpit deck to sort the freshwater tank/connections/pump. I will (finally) take pictures as I go through a removal and install.
Old 07-05-2020 | 06:29 AM
  #36
Thanks, I know the floor is just screwed in and sealed with 5200. Dustin Carter has had them out before if you need some answers. I replaced the cable then power steering pump on mine, it was a little better but still not right. Now I decided to go full hydraulic. It's tuff docking with very little assist.
1Zoom is offline
Old 07-05-2020 | 07:19 AM
  #37
BDiggity's Avatar
It's easy. About 12-15 bolts or so along the edges. Then the trim sealant. The hardest part is moving it once out. It's so large & odd shaped that it wants to tip over or bump into everything in every direction.
BDiggity is offline
Old 07-05-2020 | 08:58 AM
  #38
Thanks, my thoughts are to wait until the end of the season and then pull it and do the rollers. The season is to short to tie it up now.
1Zoom is offline
Old 08-07-2020 | 10:07 PM
  #39
Chris, I finally caught a brake and will start on the door catch for you. I will let you know when I get it done.
1Zoom is offline
Old 08-20-2020 | 04:54 PM
  #40
Thanks!
