Dyno results
She ran like a champ today, starts right up, idles great, sounds great, runs like a sowing machine.
Beautiful consistent A/F ratio.
All my mods this winter were geared towards reliability not power so I`m happy with the results.
She was quite Anemic last year with no midrange punch whatsoever and constant battle to keep clean up the A/F ratio along with only getting to 5200rpm.
I was one boat ride away from disaster with several valve hanging up, worn out valve guides , oiling issues..and quite the mess of mismatched components especially in the valve train.
The springs in the heads were good springs, just too light on spring pressure. The Hi-RPM Race morels called for 200-225psi on the seat, and 500-575 open. The springs used were around 155psi on the seat. The Hi-RPM version of these lifters are valved for the extra spring pressure. Bob and my head guy, spec'd a new spring, that not only gave us the correct pressures, but also fit the installed height, and proper distance from coil bind, to help eliminate any spring surging. I`m also switching from straight 50weight to synthetic 15W-50.
My guy @ High Flow Heads did a fantastic job with the combustion chambers and together with Bob M. they came up with an excellent valve train package. Isky tool room springs, marine endurance Scorpion rockers.. New .135 wall pushrods, .. lengths determined by the mid lift method. Replaced the tired MSD distributors and old ignition boxes, with new distributors and Crane marine boxes, and crane LX92 coil to replace the MSD blaster coil. Replaced the arp head bolts with ARP head studs. Installed valve spring oilers. Replaced leaking K&N with Teague Tall breathers (no more leaks) replaced short exhaust rocker studs with correct length etc etc..
Then my boy Mild Thunder got all BoB M. Jr. on me and we went crazy on making sure we had the best valve train geometry possible. (Budman IV was our inspiration
Today the 3 amigos (Mike Tic Tac, Mild, and myself) spent some time playing around but in the end ended up exactly with the same set up as I brought her in.. same pulleys, same jets. That gave us the most power and a smooth 900 rpm idle.
540CI
JE pistons
7:9 Compression
Dart 345 Iron eagle heads
Isky tool Room springs
Morel Hi-RPM hyd roller lifters
Crane 244/256 .632/.632 114LSA cams
With the current pulley combo, I am 3 percent underdriven. With that pulley combo with the old 871's, I got about 4psi of boost. The new to me blowers got new bearings and seals, but the stripping was still in spec per Dyers when they inspected them.
interesting side note.. the intake air temperature gauge only showed a max of 135* under boost (under the blower) it would actually drop from a heat soaked 150* when the motor went WOT. Will be further interesting to see the temps in the boat.
Heres some pics :
) Today the 3 amigos (Mike Tic Tac, Mild, and myself) spent some time playing around but in the end ended up exactly with the same set up as I brought her in.. same pulleys, same jets. That gave us the most power and a smooth 900 rpm idle.
540CI
JE pistons
7:9 Compression
Heres some pics :
mmmmm this thread delivers!
Plumbed in spring oilers:
They call for a .750 reach plug, and heads had .460 reach plugs in them.
Fel Pro MLS gaskets
Intake temp gauge sensor:
Proper length rocker studs and bellhousing dowels.
No spring locators were causing the springs to eat away at the valve seals.
We replaced the comp cams fixed guideplates, with dart adjustable guide plates, as the roller tips of the rockers were half off the valves.
Finally Dyno sheet:
Video:
http://33outlaw.zenfolio.com/img/s2/v53/o548260849/c1/p602103167-215.mp4
P.S. Please understand this is not a bash thread but a tech thread lets keep the comments on the build please and not on the mistakes of the past.. I`ve moved past that am looking forward to the future
thank you.
what a sexy *****!
The girl isnt bad either
Fel Pro MLS gaskets
Finally Dyno sheet:
Video:
thank you.
Fel Pro MLS gaskets
Finally Dyno sheet:
Video:
thank you.
