Bbc 454 build.
Old 10-14-2020 | 04:24 PM
  #211
Originally Posted by JaniH
ARP 2000 sounds great solution! what would be the arp part number for EAGLE H-beam 7/16" cap screw rods bolts, arp-20000?. what torque specs i should use with arp2000 bolts, rod manufacturer or bolt manufacturer?
Bolt Torque
speicher lane is offline
Old 10-14-2020 | 04:31 PM
  #212
TomZ's Avatar
If you haven't already purchased the rods, the ARP2000 rod bolts should be an option. This is the part number for the rod with ARP2000 bolts included: CRS6385D2000.
Eagle will have instructions in the box for proper torque and stretch. I would use the stretch gauge method.
TomZ is offline
Old 10-14-2020 | 04:39 PM
  #213
I think my rods are lil overkill for my compo so the 8740 bolts could work, but i might upgrade my heads and cam in the future.
-Arp-2000 bolts, part number arp-20000
-Arp-8740 bolts, part number arp-12000
JaniH is offline
Old 10-14-2020 | 04:51 PM
  #214
I allready have eagle 6.385" h-beam rods with 7/16" l19 bolts. Rotating assembly is balanced, would there be weight difference between the 8740, 2000, l19 bolt materials?
JaniH is offline
Old 10-14-2020 | 07:54 PM
  #215
l19 is a stronger bolt than arp2000.
mike tkach is offline
Old 10-15-2020 | 12:12 PM
  #216
SB
Originally Posted by MILD THUNDER
$700 for one cam!?
Originally Posted by SB
A person the other year got a cast cam for that $$$&. Thus my questions on cam core type.
SADI cam core. I am not an expert, but i think the reason for two different intake lobes can be found from head flow numbers i posted before.
And now there is several. Ugggh.
Am I still not allowed to say anything Mild Thunder ?
SB is offline
Old 10-15-2020 | 02:13 PM
  #217
Im not twitter or Facebook looking for censored opinions! Lol
All i know , is I pay $360-370 for a billet hyd or solid roller custom grind from comp. My cost. Never priced a sadi core , but id imagine it would be $300 or so
MILD THUNDER is offline
Old 10-15-2020 | 05:19 PM
  #218
l19 bolts and a $700cam for a 400hp motor .
I don`t even have that in my 1000hp motors .. who the hell is picking these parts?
ICDEDPPL is offline
Old 10-15-2020 | 09:28 PM
  #219
janiH.the clamping load differs from different bolts,keep in mind that the big end of the rod gets honed to size with the bolt torqued to spec,if you remove the L19 bolt and install an 8740 or a arp 2000 bolt the big end bore will no longer be round.you don,t want that do you?
Old 10-16-2020 | 01:28 AM
  #220
This build started as budget build 454, cast crank, scat i-beam rods. The 454 block i was about to use was corroded, all the 454 blocks i could find here was 1200$ most of them old marine blocks, the peanuts was allready ported with new stainless valves and flowed nice to support my goals. Then found good deal 502 block for 800$ that had never seen salt water, and thats when the snowball started to roll. We dont have that great selection of used bbc parts here in Finland.
JaniH is offline
