Still rattling
Old 08-15-2018 | 04:26 PM
  #91
I’d still pull out the shift fork... you’re already half way there
JaayTeee is offline
Old 08-15-2018 | 04:29 PM
  #92
35fountain's Avatar
this is the other drive the one that had no problems.Starboard, I just pulled the top cap to swap them and now i have 2 drive issues.
At this point since i won't be going boating now i just may pull the fork on the noisy drive
35fountain is offline
Old 08-16-2018 | 05:41 AM
  #93
35fountain's Avatar
it shouldn’t be completely full, there has to be an air leak at the top cap o ring, the shift shaft o ring or the rear cap seal... it should be not much higher than the vent hole, once it’s that high, oil should be pushed into the bottle
If it had an air leak then wouldn't water enter, wouldn't you see a stream of oil sitting in the water engine off, and wouldn't the level of the bottle drop. What pumps the oil up to the top bearing in the cap? That air gap between the vent hole and the top of the drive, that air is supposed to work its way out through the bottle.
According to a merc mechanic you fill the drive to the vent hole then you make sure the level in the bottle is correct. After a few runs the level in the bottle will drop because there is air inside the top of drive and eventually that will come out.So you will have to add oil. I used to do it that way but now I drain the oil from the drive and i remove the cap on the oil bottle. The bottle should drain also if it is working correctly. Then i fill from the bottom of the drive and after it comes out the bleed hole i cap that and i keep pumping until i see 1/3 of the bottle filled. This way it gives room for expansion.You may have to add a bit a few times. I have friends that don't even take out the bleed port. They just fill it to the bottle mark and that's it. I think that oil level in my drive saved the drive from blowing up.
Old 08-16-2018 | 07:24 AM
  #94
I have always just filled them from the bottom until the reservoir was half full. Never saw the need to remove the top plug.
snapmorgan is offline
Old 08-20-2018 | 05:55 PM
  #95
35fountain's Avatar
Default I think I found something
Today I took the noisy drive apart. I removed the shift fork for a test on the rattling noise. When i pulled the top cap off I noticed the race on the cap was different than the other drive. The race was wider and thinner and when it was on the cap it was lower than the casting. I was told that when you install these caps the race presses against another type of washer with needle bearings and it pushes down on the gear assembly setting also lash. So how could the race that was on the cap sitting below the casting push down on anything. I looked up these race's on Mercruiser parts and they make 3 different sizes. starting with .091, .094, .097 thicknesses. I got a new cap for the other drive that had the cracked tower race and the guy whom I bought it from sent me a bunch of extra stuff. He sent me the needle bearing washers and all these races brand new from Mercruiser No charge. So i started with the .091 race and placed it on the cap. Now it is slightly raised above the casting. Tomorrow will be the real test on startup. see pics + video
Old 08-20-2018 | 06:53 PM
  #96
35fountain's Avatar
took it out today...was easy but putting it back maybe an issue...please read my last post interesting what i found
thanks
Old 08-20-2018 | 07:48 PM
  #97
I thought you had a drive mechanic build these drives?
sutphen 30 is offline
Old 08-20-2018 | 08:37 PM
  #98
Default Shims
FYI if your gears have ever been change to the newer style thick floored gears the 091,094,097 shim should now be .051,054 or .057.
Clustergear is offline
Old 08-20-2018 | 09:10 PM
  #99
253
Is this a 1990's year model,,thin floor housing that has newer thick floor gears installed.
253 is offline
Old 08-20-2018 | 09:51 PM
  #100
01_17.pdf This is the bulletin for the thick floor gear replacement, might measure the thickness of your thrust races, if you still have thin floor gears and you have the thin races for the new style gears, you might have a tad bit too much clearance
JaayTeee is offline
