IMO......Formula may have a safety isssue with the hull/deck bonding.
#273
The boat you are talking about was the one with the paint job with the flames on it. I think it was called Lil Devil or Red Devil of something. It did not blow apart. That same guy's bother had a Fountain that he cracked the hull pretty bad on also. I talked to those guys at the Nor-tech both at the Miami show and they were bragging how they beat the $hit out of there boats. There was also an MTI in that Porker Run that busted the bottom up pretty bad. It turned into a big debate about who makes a better boat, MTI or Skater. Both outstanding boats. I have a friend who runs a Cig really hard and has come in with his rub rail sticking out about 2-3 ins from his boat on each side about half way down the side of the boat. Not saying anything bad about Cig, He runs his boat hard in really ruff water. I would think that running 380s on my boat would put more stress on the hull and deck than one with 280s and again I have not had and problem. Any boat can be broken if you run it hard enough in ruff enough water. Just because the rub rail screws come a 1/4 of a turn loose doesn't not mean your boat is going to blow apart. I think one of you guys said that this happened in 2005. Do you still own your boats, if so why ? Again Im not trying to start a big debate here. I have seen a lot of post that you guys have put up and there is no doubt in my mine that you are good guys that are truly concerned about the safety of others, but I don't feel that there are many 382s out there with this problem. Just my 2 cents worth. Thank you
#274
Sorry I was wrong about the name of the boat. His brother told me he at one time had a Fountain that the side cracked on. Really doesn't matter now. My boat doesn't have this issue and that's all I really care about. Sorry if I pissed anybody off. Just know of a lot of Formula's that are nice boats that don't have this problem. Hope you guys have a safe summer in 2015. Take care
#275
This tread is starting to go no where. The screws backing out is a sign of weakness of the joint. If the bond breaks the two surfaces will move making the screw back out. If the bond breaks and the screws are still tight they more than likely sheared off/bent so they appear tight. Only real way to test is to remove the rail and insert a wedge to see if joint spreads.
Do I get a cookie for good comprehsion
#276
Just want to be crystal clear for any other 382 owners that may be worried about this potential issue. It's worth 10 minutes of your time to unscrew a section of rail and check the joint in the off season. It's a very easy fix, and just got a quote on the materials for under $100.00. That's my recommendation, but take it at its face value of $0.00.
#278
#279
Hogie Roll, thank you for pointing out that you think I'm stupid but I really think I will be ok.
