The complete 242 thread
#81
Hi new to boating and just bought a 90 242ls with an aluminum headed punched out 454 now a 496. Boat runs great and I've seen 75mph on the gps. It also has bravo x with an imco lower unit. My question is does anyone have a wiring diagram for this year and model they could email me. The previous owner started replacing the original gauges with white faced ones, he installed a gps speedo and tach and I now have finished the rest of them. My problem is it seems the gauges I installed only work half the time, I'm guessing a loose ground but I don't know where to look. Any help would be greatly appreciated.
#85
Had a '87 242-SR1 for a number of years. Great boat!! With the twin small blocks, it's azz heavy-so lands great when running in the rough. Built like a tank. That boat will probably take more than your body. The twins at that time are not counter-rotating, but still handles well around the dock and backing.
#87
Boat will run mid 60's.: 65-67 range. Factory rating was 65 MPH. They'll run this fast with light load, and it needs chop. If it's too flat, it can't get enough air under it to loosen it up. It's a heavy boat, so need to get it to dance to get the top end.
#88
Speed is not to bad then, so it sounds like the boat does handle the rough ok. Do you think i would be better to wait for a 29ft as the price on this 242 sr 1 twin is 20,000 cdn. I am in Bc.
Thanks again for the reply
