Who's running a #6 in a single engine application >
Old 09-02-2009 | 12:53 AM
  #51
shifter's Avatar
www.weismann.net
Do you have the bravo on a box?
A couple questions.....
What ratio and prop are you running now?
What rpm are you going to run with the new blower?
What are you looking for speed, reliability, handling,??????
Why did you change the blower???
How much power?
A photo of the transom would help.
pat W
shifter is offline
Old 09-02-2009 | 01:18 AM
  #52
Originally Posted by 26 REDLINE
I can do the #6 without moving the engine... With the Arneson I would have to build up the center pod of the boat, trust me the arneson is bad a$$ but sounds like alot of work, but whatever I do will be alot of work...we will see...
The engine will have to be moved forward in order to accommodate the transmission for the #6. Don't quote me, but I believe it's 18".
Darrell.
DMOORE is offline
Old 09-02-2009 | 07:04 AM
  #53
How much power?
pat W
Pat,
I will call you later today about this project.
The Max Machine drive is on an IMCO box.
1.35 ratio 34 pitch custom lab Bravo.
The new blower has been on for approx 75 hours already and is running as high as 6500.
Speed, handling and reliability would be nice but reliability and maintain the current handling is really most important to Jeff.
Steve
Attached Thumbnails Who's running a #6 in a single engine application-img_0151b.jpg
stripp is offline
Old 09-02-2009 | 08:49 AM
  #54
Darrell.
Yep. Unless you have one of those 572's that is really a 540! Just because he told you that there is room that does not mean you don't have to move it.
Bryan Rose is offline
Old 09-02-2009 | 09:11 AM
  #55
lake speed's Avatar
what are you talking about? unless you go to a 5" bore spacing the length from front to back is the same on a bbc.
lake speed is offline
Old 09-02-2009 | 09:54 AM
  #56
I know. I was just joking about the time Redline here went around saying he had a 572 and found out it was really a 540.
Old 09-02-2009 | 10:25 AM
  #57
The thread is abut drives, not what I am running, what are you running besides your mouth...
26 REDLINE is offline
Old 09-02-2009 | 10:51 AM
  #58
shifter's Avatar
www.weismann.net
Did you lengthen the skeg?
What is the distance from the notch to the end of the prop?
pat W
shifter is offline
Old 09-02-2009 | 12:51 PM
  #59
pat W
Hey Pat,
Steve is supposed to be calling to discuss everything with my current setup, I appreciate the help.
Jeff
Old 09-02-2009 | 01:11 PM
  #60
Brad Zastrow's Avatar
Originally Posted by mmareno
My .02 is that a # 6 is a lot of weight and uses a lot of HP to run..
Good luck
The #Six will weigh more that would be my biggest concern on a 26 boat.
The old wet sump sixes eat up power as they hold about 5 gals of oil. The dry sumps will use the same or less power than a bravo drive.
Brad Zastrow is offline
