Thad Allen's Apache + The Birth of the Cheetah Cat >
Old 05-09-2010 | 12:07 PM
  #191
Steve 1's Avatar
My crew.
Attached Thumbnails Thad Allen's Apache + The Birth of the Cheetah Cat-crew.jpg
Steve 1 is offline
Old 05-09-2010 | 12:09 PM
  #192
Steve 1's Avatar
About the weight, everyone thought it was BS back then they were saying it would sink at the dock,so I stopped talking to people.
The target was 1200 pounds for the first Cat. What you see sitting out in front of my shop there is much Less than 500 pounds and that was the projected weight at that point, now the inside glass,deck and internal structure are coming up here but the whole thing in my head then was how this was going to agree with my initial estimate ,
which could not be checked until I could weigh the thing, logging material gave me a clue during the first phase but as you know the Bag disposables and batch bucket residue tools Rollers washout , there is a lot of unknowns.
Everything is conjecture until it hangs from accurate scales.
Steve 1 is offline
Old 05-09-2010 | 12:10 PM
  #193
Steve 1's Avatar
Attaching the foam core;I used #14 Screws from the backside that was the reason for the Pine 1x3 Battens so they would not break or flex when drawing the 1" foam panel edges up also the reason I left the deadrise open to fasten the tunnel Core in place BUT!!! Removing the screws in some cases was done by hand fortunately the hull was right side up which made it a lot easer.
Steve 1 is offline
Old 05-09-2010 | 12:14 PM
  #194
Steve 1's Avatar
One more from the roll out.
Attached Thumbnails Thad Allen's Apache + The Birth of the Cheetah Cat-outside3.jpg
Steve 1 is offline
Old 05-09-2010 | 12:17 PM
  #195
Steve 1's Avatar
Tonights work setup, the Glass weighed ,The Resin weighed out, Vacuum Bag under the peel ply and breather on the side of the hull vacuum pump checked and the pipe setup and laying outside beside the boat. The fabric is S ,E and E uni. There was some spectra in the deck.
Steve 1 is offline
Old 05-09-2010 | 12:22 PM
  #196
Steve 1's Avatar
Another picture of the last panel, I left the tacky tape off the work walk way area as it does not like resin or being walked on.
Steve 1 is offline
Old 05-09-2010 | 12:23 PM
  #197
Steve 1's Avatar
This job is 50% setup, strategy and 50% actual work, the bag has been placed and the large pigs ears tacky taped then carefully folded over the side and placed outside, the breather next and the peel ply, the last run of tacky tape about roll and a half is placed within reach .
Steve 1 is offline
Old 05-09-2010 | 12:25 PM
  #198
Steve 1's Avatar
Rolled the Cat up on it's side, the bag and disposables are stripped out,Now I have the bulkheads on a bench done, a couple stringers left to build and bag into place. Straight back on the wall is a simple fixture I use to pick off shapes.
Steve 1 is offline
Old 05-09-2010 | 12:28 PM
  #199
Steve 1's Avatar
Running out of Time, Some quick deck framing.
Steve 1 is offline
Old 05-09-2010 | 12:31 PM
  #200
Steve 1's Avatar
Airex core being placed on the deck framing at this time ,The tunnel stringers have been bagged into place.
Steve 1 is offline
