25 outlaw 675 sci help
Old 06-17-2012 | 11:34 AM
  #31
AIR TIME's Avatar
Originally Posted by Rwbrew3
2.3l whipple, max boost is 4.0lbs is what i was told... I'm new to the sc motor world but getting it down pretty quick! I have had the boost up to 5.5 but rev limit was met and had throttle left, I hit 81on gps but it started to walk on me, hydraulic steering before I play there again, tried pushing thru it but ran into boat traffic, not sure if it would have settled down at higher speed or not!
no it wouldn't. great looking ride.
AIR TIME is offline
Old 06-17-2012 | 02:06 PM
  #32
Rwbrew3's Avatar
Thanks, I was going to see next time out if I could push through it, I'm going to waite for the hydraulic steering! anyone recommend a brand?
Rwbrew3 is offline
Old 06-18-2012 | 10:22 PM
  #33
Imco.
Baja_man is offline
Old 06-18-2012 | 10:30 PM
  #34
Have u tried a non labbed 26?
dieselstrng is offline
Old 06-18-2012 | 11:11 PM
  #35
Rwbrew3's Avatar
No, just the 26lab, what do you think the difference would be? I'm even thinkin about a 30 now!
Rwbrew3 is offline
Old 06-18-2012 | 11:13 PM
  #36
Rwbrew3's Avatar
How do I go about finding Dustin on here to talk to him about my set up?
Rwbrew3 is offline
Old 06-19-2012 | 07:05 AM
  #37
I would worry about the RPM not the boost i dont think you will be able to turn a 30 pitch i had the same boat with a blower motor and ran a 28 bravo out of the box not labbed and ran mid 90"s at about 5,800 Rpm, 4 to 6 psi sounds about right in most blower motors. try a prop out of the box if one is available. you could also take the hook out of the bottom to get a little more speed if you have real trim tabs or k planes.
You can probably call whipple and speak with dustin.
tony stamis is offline
Old 06-19-2012 | 07:08 AM
  #38
Default 25 outlaw
1999 25outlaw
Old 06-19-2012 | 09:25 AM
  #39
Rwbrew3's Avatar
Thanks Tony, i think I'm going go buy a 28 no lab and try it, or maybe borrow one, I have crap for tabs but looking at getting bigger for sure, these stock ones are junk.
That a sweet looking boat ! What ind of speed do you think I can get once I'm set up right, I was thinking low 90s
Rwbrew3 is offline
Old 06-20-2012 | 04:14 PM
  #40
Rwbrew3's Avatar
Maybe someone can help, my boat stopped throwing water ( not sure what this is called ) spits like a out drive motor, part of the cooking system, any I noticed there was very little coming out, im took the rubber hose off and there was a little piece of debri, looked almost like bamboo,shaped like a pencil erraser, I removed it and water is now flying out of ther, however, my water temp is running hotter now at idle, at plain it fine. Any ideas what this might be?
Rwbrew3 is offline
