Salt water help
Old 10-28-2015 | 08:46 PM
  #91
Originally Posted by 1MOSES1
And according to you all boats are dry!! HAHAHA pass the pipe!!! Never responded to my comments. Not sure why I acknowledge your existence!!! Bahaha
Wow, that was exuberant. It is hard to argue with morons like you hence my lack of response. You are wearing me down and beating me with stupidity. Boats should be dry as far as the structure and I never said that all boats are dry. Wet boats are a nightmare.
JRider is offline
Old 10-28-2015 | 08:57 PM
  #92
By the sounds of it we should rename the forum from offshoreonly to offshorenever...HAHAHAHA
Not sure if this is directed at me or not, but I'll run with you anytime on "offshore never" Lake Michigan. Earlier in this thread you said nobody could tell if your boat was run in salt, post up some pics of your boat. Engine compartment, transom, trailer. I like cigs and have never seen your boat
jbraun2828 is offline
Old 10-28-2015 | 08:59 PM
  #93
So I guess seals don't go bad, caulk doesn't dry, and bolts never loosen!!! I'd guess more than half the boats on the market have some type of water intrusion. It's a fact of life. I'd be willing to bet your boat has moisture. Go live under a rock.
1MOSES1 is offline
Old 10-28-2015 | 09:10 PM
  #94
PM me your email and I will send.
1MOSES1 is offline
Old 10-28-2015 | 09:17 PM
  #95
rak rua's Avatar
I'm a salt water boater and have been all my life. Thanks to about half of you guys, I find myself developing thalassaphobia, better known as a fear of salt water. I'm even thinking about eating French fries without salt!
Seriously, all boats need preventative maintenance and if you're in salt water, allow a little bit more cleaning time to keep things looking new. Every time my boat hits the water (it almost never stays in overnight) I know there will be 3 hours of cleaning afterwards.
If you think 100% of salt water boats are not so good then don't buy one. Simple. Personally, I would never overlook a saltwater boat, I've always owned them and with the correct maintenance, I've never had any significant issue that would not have occurred in fresh water.
RR
rak rua is offline
Old 10-28-2015 | 09:22 PM
  #96
Never argued any of that (except that my boat has moisture, because is does not) your garbage was not really worthy of a response...and probably still is not.
JRider is offline
Old 10-28-2015 | 09:24 PM
  #97
Can't post them? Too cheap to pay for a membership?
JRider is offline
Old 10-28-2015 | 09:31 PM
  #98
Yes
1MOSES1 is offline
Old 10-28-2015 | 09:32 PM
  #99
keep your blinders on pal!!!
yes garbage, the fact that fresh water rots wood faster than salt which you disputed!!! Gotchya!!!
1MOSES1 is offline
Old 10-28-2015 | 09:37 PM
  #100
rak rua's Avatar
Yes
Nice answer. Short, simple and straight to the point.
LMAO
rak rua is offline
