Poll: Synthetic engine oil or no? >
View Poll Results: Synthetic oil or not?
Yes I use synthetic oil
301
65.72%
No I do not use synthetic oil
140
30.57%
Hell, I don't even know where the oil cap is
17
3.71%
Voters: 458. You may not vote on this poll
Old 02-17-2003 | 03:56 PM
  #51
ApachePete's Avatar
Default Joey and Bobby,
Thanks for the info. Now I'm a bit worried. I hope the guy at least knows how to do a rebuild!
Guess I'll find out soon.
ApachePete is offline
Old 02-17-2003 | 05:14 PM
  #52
mcollinstn's Avatar
audacity,
I know you've done extensive testing and stuff, but I've been told that while Merc Hi-Perf is synthetic, it uses a different base composition for the simple reason that it will absorb water and still perform. This was a requirement of the Merc spec cause not everybody changes drive lube as often as us guys and they didn't want the headaches of water intrusion warranty concerns.
The water-absorbing makeup gives up some desirable qualities in order to get it to absorb the water.
Feel free to correct me if I am mistaken. We are all here to learn.
mcollinstn is offline
Old 02-17-2003 | 05:42 PM
  #53
this may very well be the truth about merc lube!!!
all synthetics are not the same!
for me this would be a 100% moot point...we change the oil every weekend, even on our pleasure boat...we always pull the top cap off the drive to inspect as well...very easy to do and it speeds the oil change up big time.
audacity is offline
Old 02-17-2003 | 10:41 PM
  #54
25 Eagle
M1 in everything, never a problem. Some new cars come with synthetics, the Vette is one.
Old 02-17-2003 | 11:59 PM
  #55
Great thread. The "OIL" issue has allways been a good one. I have been researching the synthetic oil issue for a while and think that is the way to go for my engines. I have pre-lubers to help with the long down time beween starts. This post by Audacity does make me question using sythetic in my drives
I don't mind changing the oil in the outdrive ever 25 hours with the engine oil........but after every time we take the boat out........that is just not practicle.
Sounds like I should stick with the Merc oil for the drives.
h2owarrior is offline
Old 02-18-2003 | 08:28 AM
  #56
MODVPSST
Originally posted by bobby daniels
Just alittle warning ,Blower motors need syn. oil 10 times worse than n/a motors the load on the bearing is by far greater and heat build up is higher ,this is where the syn . exccells in loads and heat ! Its tons better,!!!!--- Mobile 1 ,amsoil,royal purple ,heck any of them would far better protection in a blower or NOS,motor ,Look at indy cars with 50 lbs of boost they run syn .
Hope this helps you understand
have a good week-end
What I was told is that Synthetic oil may allow the bearings on High HP blower motors to "slide" rather then "roll" creating flat spots on the bearings.....
Old 02-18-2003 | 08:52 AM
  #57
mcollinstn's Avatar
MODVP
The only rolling-element bearings in an auto/marine I/O engine are the roller lifters and roller rockers (if it has them).
Those bearings will be under the same loads and conditions in a blower motor as they would be in a NA motor.
As far as roller lifters flatspotting, the Heavier or Thicker the lube film, the higher the chance of stalling the roller. AND it is more apt to occur at low rpm with heavy lube in a cold motor. One of synthetics' biggest advantages is its resistance to cold weather thickening.
The tips on roller rockers have been shown by high speed camera to either "not roll", or "roll backwards" at certain rpm. This behavior is more due to harmonics in a dynamic spring-loaded condition (think of those Gee Haw sticks where you make the propellor spin different directions) than any sort of lube film breakdown.
I notice your name MODVPSST. Your Merc outboards have rolling-element bearings all over them. The crank bearings, the rod bearings, all of them. I would recommend synthetic non-castor 2 stroke lube for you to run in them as well.
Old 02-18-2003 | 09:16 AM
  #58
bob
Charter Member #40
Lubricants are always a great topic! I will try to comment on a conversation I had with GM lubricant product specialist, actually she had her phd and was provided to speak at a customer's meeting where many oem were asked to make lubricant presentations/recomednations. She has writen a few papers and are all way above the layman's level of comprehension. One of the main reasons she felt synthetics were of a benefit in passenger car operation was that the oil has the ability to "re-juvenate" itself, at least in her reference to Mobil1. Apparently when a normal crude oil takes on moisture some degree of permanent damage occurs to the additives in the oil. As I recall, with Mobil 1 the damage is not permanent. There were other benefits also associated with the Mobil 1 where she advised me that in my high performance application it would be worthwhile to make the switch...and I have. As a side note, the intent of my questioning was not to obtain her opinion on the best synthetic but rather comparing Mobil 1 to crudes.
bob is offline
Old 02-18-2003 | 09:26 AM
  #59
mcollinstn's Avatar
Bob,
She must've been pretty hot, eh?
Old 02-18-2003 | 09:37 AM
  #60
MODVPSST
Originally posted by mcollinstn
MODVP
MC.... What you say certainly makes sense.... I am relating what my engine builder has told/shown me... I do use Mobil 1 in my HP500.... I use a product from Alisyn for my 2-stroke... for anyone interested they have a website Alisyn.com & I highly recomend thier gear lubes as well as thier 2-stroke product... Take a look Alisynlubricants.com... I think... it might be Alisyn.com... I'll check.... but thier good people & I can't say enough about thier gear lub's....
