Biggest HP on pump gas? >
Old 11-17-2008 | 03:09 PM
  #81
Whipple Charged's Avatar
Originally Posted by HotPursuit
WOW sounds like you have to get to that max RPM of 20K to make some power
20,000rpm will produce nearly 30psi on 600ci motors with Pro1 heads. This equals 8 high dollar ash trays.
Whipple Charged is offline
Old 11-17-2008 | 03:11 PM
  #82
Originally Posted by pbam22
. I would also like to clarify, I feel AJ is an excellent cart driver and his dounuts are simply remarkable!!
It was a great time and really great meeting you , just think if my cart had whipples on it [/QUOTE]
Well if your cart had Whipple's, it clearly would run slower but show more power on the dyno! LOL Well be catching up when I come to Mark's, you guys get to show me around New Orleans, just remember I'm just a rookie
Old 11-17-2008 | 03:21 PM
  #83
We're these Whirples on the teague motors in the 388 test on parker thats in Powerboat ???? what size ??? if so did you DYNO them at 1200 Cali correction factor ?
Old 11-17-2008 | 03:41 PM
  #84
OK Dustin
1 How much more will the 8.3s make over my 1471s . 605cu in Big M heads solid roller 780 lift. Msd ignition 1150cfm carbs looking for peak power @ 6500 4.610 x 4.500
2 How much faster 40 Skater drysump 1:35 props 16.5x 38 1200hp c&c mercs. Hull rig weight with 100 gals fuel / under 10,000#s and a X height of 3.25"
I wish Bill,Jim,AJ and anyone else who has installed either SC would pipe up with a speed increase.
3 RunningHot posted he would dyno his set up when complete. I would like to see a comparison in real live conditions. Run my hull like its set up make the sc changes and lets see what the increase in rpm and speed is gained. This would equal your Dollar per mph gain.
4 example Spent 12k to dry sump my drives,picked up 6 mph which merc claims the dry sumps are worth 85 hp. If I see even 100 hp gain this should come close to 8mph or 200hp gain should give me 15mph right inline with Skaters #s from the factory. 2k per mph gain.
What ya think
If ya get tired of my questions let me know!!
1. Gotta have a boost number, what current SC has. Also, what size IC, can only pass so much air through some of these single core IC's. What duration on cam? What heads, what manifold? If you want accurate number, need far more data.
2. I don't design boats, nor do I know the cabability of your 40. But again, need more data to give you an estimate. First, what RPM/Speed are you running with 1.35 and 38' props?
3. Not sure what this question is. I agree, it would be nice to see mph vs. power difference vs. dollar spent.
4. Sounds pretty good, but at higher speeds, its not a 1:1 ratio or 2:1, when getting into speeds over 150mph, many other things come into factor and its not always about hp, although it certainly helps. So if it picked up 6, it doesn't mean another 85hp would get you 6 more. It should be close, but, you have everything else working against you at those speeds.
Old 11-17-2008 | 03:46 PM
  #85
The Kramer 388 Skater has Teague 1200EFI's with our W305ax superchargers. The boat is built for Lake Tahoe, 6500ft and has the same pulley's as sea level, negating 3-4psi of boost @ Tahoe. Therefore it's prop/gear combo is setup for just that.
I didn't dyno the motors, but when we dyno, we use the proper correction factor. By the way, instead of correction factor, you should mention "cali" gasoline, just about the worse in the 50 US states. And the motors do make 1200hp, actually a touch more.
Old 11-17-2008 | 03:51 PM
  #86
C@@l BIG Daddy i heard it was built for Parker and thats the fastest lake in Cali - Arizona
Old 11-17-2008 | 03:59 PM
  #87
dustin, how come you guys didn't produce a 9.0? therefore, being able to slow the blower down. please explain this in a little bit of detail, i'm trying to figure this stuff out.
We did, we had the 9.8 liter male driven supercharger. We built what we felt would still be manageable in multiple applications.
Old 11-17-2008 | 04:09 PM
  #88
Dayum BIG Daddy your gettin way to Serious , instead of watchin your homeboy/ Commander & chief head to the Tittie bar
Get some prices on 4 PSIs & quit phuchin around
Ya, have fun with distribution! And I think HP already went down that route. Also, better order now, only takes 3 months to get them, and if you need a part after, just make sure to make plans for breakage 3 months in advance!
Old 11-17-2008 | 05:06 PM
  #89
Now thats funny BIG Daddy but we aint gunna break
Old 11-17-2008 | 05:15 PM
  #90
Dusty are you going to bring the 9.8s back around seeing your thoughts on the PSIs they are'nt worth a hill of beans ... Or do you still have them ???? See ya in Miami
