raylar with headers >
raylar with headers
raylar with headers
Old 12-29-2008 | 06:10 PM
Looking to install 525 kits on my HO's in my 35 outlaw. Boat is running 71-72 GPS what speeds are realistic.
redbud35 is offline
Old 12-31-2008 | 11:10 AM
Wink Raylar Kits make 496's Rock!!
adding Raylar 525HP kits to 496 mag twin engines will net you 300 more horsepower with stock exhaust. I feel your boat will need about 18-20HP per mile an hour increase in speed which should translate to about 15-17 mph more speed in your Baja 29 if the boat has a normal setup and bottom. You should easily see 83-85mph with that boat and our Raylar kits. The midrange cruise speed and fuel economy difference will also be a big surprise and benefit.
If you upgrade the exhaust you might even see close to 90 mph out of that boat. If there are soe OSO'ers here with Mercury Racing HP525efi's in that boat or some test results on that setup it should confirm my input as they make about 540HP at the crankshaft.
I think you will have nothing but a BIG GRIN on your face after upgrading you 496 MAG's to 525HP each!!
Best Regards,
Ray @ Raylar
Raylar is offline
Old 01-08-2009 | 06:22 PM
Raylar can you mail me
@[email protected] so we can talk more
29 sst is offline
Old 01-08-2009 | 10:25 PM
Originally Posted by tfarmer
Do it. Its not overkill. It is still turn key setup. I done the 525 kit with the CMI sport tubes/billet throttle body. I put on the headers first. They are good for 5 mph alone! GPS.
Hp and still turn key. If you want to stay with the 496 its the way to go. Power, great sound and is never stalls or stumbles.
Dont get me wrong its not a 598 or 632 cid. But you wont have to work on it at every weekend. Just do your service work and use good oil. I use Mobil-1 15w50 Red top.
hey how many hours were on your engine when you put the kit on? how many are on it now? do you know roughly how many run time hours you put on a year??
SDFever is offline
Old 01-26-2009 | 07:09 PM
tfarmer's Avatar
[QUOTE=SDFever;2773842]hey how many hours were on your engine when you put the kit on? how many are on it now? do you know roughly how many run time hours you put on a year??[/QUOTE
The first one had 196 hrs on it. I done the kit and a piston broke at 221 hrs. It took out everything!!
I purchased a new 2008 from Ray and put another 525
kit on and it has 9.5 hrs on it now and runs great. There must of been something wrong with the other engine because
the new one is 7mph faster with all the same stuff.
tfarmer is offline
Old 01-26-2009 | 09:08 PM
[QUOTE=tfarmer;2786530]
7mph!!!
SDFever is offline
Old 01-26-2009 | 09:17 PM
tfarmer's Avatar
[QUOTE=SDFever;2786618]
7mph!!!
Yes, All gps numbers. and 11 mph faster than when is was in stock form. 496 ho mag 425 hp. And a true turn key set up on87 pump gas.
tfarmer is offline
SDFever
Fountain
7
12-30-2008 12:04 PM
pachanga
21
01-23-2008 09:04 AM
daqcraig
14
07-24-2007 01:33 AM
superwrench0166
3
10-17-2005 03:23 PM
Rage
27
10-05-2005 11:10 AM
