Would a "731" cam be too big? >
Old 02-18-2009 | 05:07 PM
My current cam has .545 lift and it runs out of power at 4400 rpm. I thought that my props that I was running were a little big,But I put the 24's back on and 4400 was it! I have changed timing up and down, I have went up and down 4 jet sizes, And I have checked fuel flow and pressure all good, Pres.-10lbs. I am now looking at the cam just running out.? It is pushing a '29 powerquest, with twin 454's about 6000 lbs.+/-.
speedreeder is offline
Old 02-18-2009 | 05:41 PM
Originally Posted by kennyo
It worked fine in my Gen VI with the stock lifters.
I'm also running a Bob cam now though!
We pulled a motor down a couple months ago and found stock lifters in it and it had a 741 cam in it , But the other motor had crane lifters. Some engine Builders you just never know.
formula 382 sr-1 is offline
Old 02-18-2009 | 09:09 PM
heres another vote to call Bob. He is the Man!
formulaok is offline
Old 02-18-2009 | 09:15 PM
You should be able to pull a lot more rpms with that cam. I spun a 454 mag with a .530/.550 lift cam to 5400-5500rpms before it started fading.
Griff is offline
Old 02-18-2009 | 09:21 PM
Im running a gen 6 with stock roller lifters and the bigger 741 cam and no problems. I went down this road with people saying I would have problems. I checked mine closely and talked with some engine builders.
whoya is offline
Old 02-18-2009 | 09:28 PM
I know that they work ,They worked for 70hrs until he spun a main bearing . and he turned them to 5700 rpm . We just could not understand why an engine builder would use two different lifters when he building two motors the same.
Old 02-18-2009 | 10:07 PM
Thats odd. Sounds like he was out of the aftermarket ones after one engine.
whoya is offline
Old 02-19-2009 | 06:28 AM
Gen vi roller lifters the max lift on the cam is 0.353 witch is about 0.630 with a 1.7 roller rocker @ the rocker is the max you want to run with the stock lifter. I'm running 228/236 @ 50 601 lift exh/ int. this cam is right in the middle of the 731 741 crane
Rockfish71 is offline
Old 02-19-2009 | 06:36 AM
Call Bob Madara, For about the same price as an off the shelf cam you can get one custom ground and will make more power with what you have. 585-654-8583
What he said.
jeff1000man is offline
bobo1
OPA/The Jersey Boyz
0
04-23-2008 07:36 PM
electrical1
11
11-09-2006 08:51 AM
mopower
5
02-02-2006 08:26 AM
BK
02-27-2004 11:16 AM
mikesufka
12-26-2002 11:23 AM
