Cam shaft numbers
#291
#292
you are 1000% NOT QUALIFIED to make a post that has a single technical thing in it. you don't own a tool, and failed screwdriver and hammer classes. You have NEVER put anything together in your life. So you quoting what you think happened to the motor is like me telling an engineer how to get a man to the moon. Just more attempts at redirection because of your screw ups.
man up straub, and admit you messed up and sent junk. All of us make mistakes, and its about time you admitted you make more than most.
The picture Bill printed of using SOLO cups to hold tooling said it all. Look at the picture with the Duramax. That's what he considers a clean room....a smart person with some simple mechanical skills and the ability to read can catch that the guide clearance was not checked in these engines and that led to the failure. Blaming the part failure is easy. Admitting that we missed a critical tolerance is another. Bill has hung himself with his own statements.
#293
and the loser you hired to build engines for you did it in a garage covered in newspaper and plaster dust. I've been in the assembly room where marine and customer motors are built when S30 works, and its spotless. Oh wait, I forgot. You backed up a poser who claimed he could do a FULL posrt job on cylinder heads in 2 hours. Yea, you back qualified people. NOT.
Again, you are NOT qualified to talk about guide clearance. You don't do it, don't own the tools to do it, and couldn't do it if you did own the tools.
#294
Doug,
as for the valve guide,you again don't know chiot and prove it w/ your comment.you know nothing about reversion and what it can and can't do.I'm not gonna teach you,you idiot.but clearance were perfect.
after mufflers were taken off,no more problems.
as for the lifters,,you sold us 5 set that were not marine special,but more like ctroll shortbus specials,coming from the head retard.
and prove it chit bag that theres tooling in those cups,prove it.Let you in on a hint you liar,,theres nothhing in them.there used water cups that get thinner put in them for cleaning brushes.
keep trying conman,,maybe we should talk about you inability to tell the truth,,about anything.
#295
now follow closely you brain dead conman,because my story won't change ever.the engine reverted,stuck avalve.we fix said engine and get lifters from you,,5 set,,remember before i said and listed the 5 engine.well 1 set chris's engine.your chit brick lifters went into this engine after the initial failure.
thanks to you,you conman,,I had the pleasure of taking this engine apart and fixing the lifters.
now go con some poor sap on chevelles
#296
this was chris's boat after he sold it.and I fixed the engines.theres other vids available of the boat I don't own says the ctroll.
http://www.youtube.com/watch?v=F7lg5TxwPeY
#297
The duramax in this thread is assembled. Duh. so it needs to be in a clean room? Its going in a truck. you think thats clean?
#298
Speaking of duramax . What's one worth with 97,000 miles lbz. 2006. With Allison.
#299
first conman w/ no mechanical skills,,that engine is behind my bench.its there for fitting.something you know nothing about,now stop diverting the attention,conman.
I think it is great that you want to be somebody in this industry. I would suggest instead of tearing down anyone that disagrees with you I would concentrate on work and doing your best. If you dont' understand something then ask someone who does. Calling people names and accusing them of having substance abuse issues does nothing for your future.
#300
conman,conman,conman,
talk all you want,the fact that YOU sold them and spec them,,and they failed to oil is a screw up by you.A good conman,always has an excuse and tries to talk intelligent.fact is,bullet designs your cams.
now go learn to change a spark plug and sell some chinese heads and lifters,,conman,
I know you like Google, so just type in Morel no oil flow to cylinder heads or morel no oil flow. You'll find a bunch who tried returning them to no avail and others who cut a groove from the oiling hole on side of lifter.
Here's one: http://www.429-460.com/t17236p75-new...-no-oil-to-top
Don't let Chris tell you otherwise. It was very for real.
