Dyno proven 675-700 HP 540CI recipes? >
Old 11-18-2014, 08:36 AM
  #31
Ignore the noise and follow your plan..... As I said before, these heads are fine for a normally aspirated build .... Thousands of these heads are running on the street every day....... Boost and super high compression with high rpm or crazy valve spring pressures are not what I would run with these heads...... Most failures occur because of these issues. I did my research......... I have these heads, I worked these heads so I have real world experience and not second hand rumor ..... My engine is a 502 with a dual plane intake so I was
After making big torque numbers. I have 10.2-1 C/R and a nice HR cam from Bob M anda marginal 496 style exhaust and I feel i am around 600lt/lbs TQ.........With the HP numbers you are after obviously you will need a good HR cam and matching springs. Good single plane intake with a good exhaust and I see your 540 making 650 plus all day long at moderate rpm levels....... Hopefully others will share their combos... Good luck with your buildup!
tpabayflyer is offline
Old 11-18-2014, 08:42 AM
  #32
Originally Posted by Full Force
Sounds like a good combo, I have MSD all in one drop in marine disributors, love them so far...!
I'd use it,,cam came from Bullet Btw.
sutphen 30 is offline
Old 11-18-2014, 05:28 PM
  #33
Ask the stihl race boat how they made out with the msd, in key west this year! I've heard of lots of msd failures, sutphen 30 set up my ignition, real simple!
shaun harrington is offline
Old 11-18-2014, 05:42 PM
  #34
out of curiosity why not just order cams from bob madera? I assume he could recommend the best match for your combo
stimleck is offline
Old 11-18-2014, 05:44 PM
  #35
Full Force's Avatar
Anything electric can fail, I have had nonissues with msd if it fails I get another....
Full Force is offline
Old 11-18-2014, 05:46 PM
  #36
Full Force's Avatar
He will be contacted for sure and see what he recommends, he ground the cams I am looking at for a near identical application that's why I was asking and I like info and seeing other combos and can adjust ideas from there.
Old 11-18-2014, 06:52 PM
  #37
Received 4,354 Likes on 1,248 Posts
I think between Mild Thunder and Sonic700 they could start a small store selling dead MSD boxes lol
Made me switch to Crane
ICDEDPPL is offline
Old 11-18-2014, 06:55 PM
  #38
SB
Received 3,130 Likes on 1,408 Posts
True on the MSD's, but not a millionth as bad as the fraudelent boxes made by Procomp to look exactly like the MSD boxes, but have a , of all things, GM module inside of them.
Ooops, did I mention Procomp and fraud (yes and they lost in court) in the same sentence.
Excuse the french, but they are as much a douchebag as a company can get.
Carry on.
SB is offline
Old 11-18-2014, 07:11 PM
  #39
SB
Okay, got fired up.
Imagine MSD getting Profraud's box back for warranty claims ? Huh ! They got lots of them.
http://forums.corral.net/forums/5-0-...body-pics.html
ProComp Box
Inside
MSD 6A + 6 Digital respectively
Crane
SB is offline
Old 11-18-2014, 07:12 PM
  #40
Full Force's Avatar
Carry on.
I didnt buy the heads, they were already on engines bud....that is not even an issue in this thread, wasn't a "what heads to run" thread...
