Shift Cable End On Keikafer Control Box >
Old 09-24-2002 | 09:07 AM
Default Shift Cable End On Kiekafer Control Box
How do you disconnect the shift cable end from the shift lever, without removing and dissasembling the control box? These are red Morse cables and dual zero effort throttle/shift controls.
It looks pretty tight up in there.
floatingphil is offline
Old 09-24-2002 | 01:43 PM
Goodfella's Avatar
GOT MERC?
Cool
Sutphil,
You have to remove a rod that runs the length of the control
box. The only way to do this is to remove it from the console
or dashboard. Once you remove the rod then the hook on the
other end of the cable will slip off it's pin.
Goodfella is offline
Old 09-24-2002 | 02:42 PM
Thanks,
I'll give it a try?
35 White Lightning
Fountain
2
11-07-2008 06:38 PM
DrFeelgood
Drives and Lower Units
5
11-05-2007 09:42 AM
atthelake27
5
07-23-2007 08:09 AM
hdtvned
1
03-08-2007 10:05 PM
obnoxus
0
05-15-2002 06:18 PM
