Flare to AN adapter >
Flare to AN adapter
Flare to AN adapter
Old 03-29-2017 | 06:06 PM
Why are you guys doing this? Is there an issue with the stock filter location and line diameter with not flowing enough oil?
TorchLK is offline
Old 03-29-2017 | 08:29 PM
I'm doing it because of the CMI headers. The relocation kit is not good to say the least. And the 496 ho Has steel lines with a 8 inch section of rubber. It just doesn't fit to my liking. For the filter adapter on the motor. No one makes one. At least that I could find. Hardin Marine said they don't exist. I only needed 2 cutting to do a 1/2 hour job which turned out to be a week. 30 phone calls. 200 miles of driving and a few empty bottles of wine. It is easy if you can find the fittings. Thanks for the help. If anyone one else needs to do this. I have the sizes and the phone number of the only place that has them in stock.
class6 is offline
Old 03-29-2017 | 09:32 PM
SB
There's filter adapters out there. I've seen a few listed. Top of my head they had female 1/2" NPT outlets. Do a search 2001 8.1L Chevy K3500 or similar.
SB is offline
Old 03-30-2017 | 06:01 AM
Thanks, makes sense. I was thinking there was some other type of restriction issue and i was interested..
TorchLK is offline
Old 03-30-2017 | 06:20 AM
Don't forget, you can use tube style compression fittings to mate to the steel tube as well.
Cole2534 is offline
