Intake or spacer >
Intake or spacer
Intake or spacer
Old 04-27-2017 | 05:11 PM
  #31
Originally Posted by getrdunn
Theyd work better on larger cubic inch or higher rpm on 500 plus or minus builds without a doubt. They have shorter runners than darts also. I really like the idea of using your current set up with Jason's spacers. You'll actually be tricking your intakes into a tunnel ram. Also will be nice to see if you gain rpm with your doms and no other changes. I would guess you will.
Like last year, lots of changes going on. The entire fuel system is being upgraded, -3 Imco's vs -2 Sportmasters, Daytona ignitions vs TB, and Eickerts vs Gils. As a whole there will be some improvement, but how much does each contribute? Who knows. I sent back the Dart adaptors today, so hopefully I can get some of Jason's adaptors, otherwise I'll go to my original plan which was the HVH super sucker adaptors.
endeavour32 is offline
Old 04-27-2017 | 05:17 PM
  #32
F-2 Speedy's Avatar
I went with the Vic Jr on my 525's and found this spacer to use
Attached Thumbnails Intake or spacer-img_0591.jpg   Intake or spacer-20170424_172114_resized.jpg
F-2 Speedy is offline
Old 04-27-2017 | 05:20 PM
  #33
I used a very similar spacer last year on my enigines. It was a 1.5" Wilson tapered 4 hole spacer. Now I need a 4150 to 4500 adaptor spacer.
Old 04-27-2017 | 05:22 PM
  #34
F-2 Speedy's Avatar
Your running Dominators on 509's ? sorry Ive not read all your thread
Old 04-27-2017 | 05:23 PM
  #35
Yes
Old 04-29-2017 | 09:13 AM
  #36
Rookie's Avatar
I'm running those right now. I'm going to try my new ones and see if RPM's/MPH increase. I will try 1" to 4". It's nice to have space between carb and hatch!
Rookie is offline
Old 04-29-2017 | 09:47 AM
  #37
F-2 Speedy's Avatar
When Smitty dyno'd my carbs he used a 1" 4 hole and a 1" open spacer, so I have the same thing with one less gasket.
Old 04-29-2017 | 08:58 PM
  #38
I decided today to just swap out the intakes and be done with it. I ordered 2 Brodix HV2001's. I've been looking at this intake for while and after a conversation with Getrdunn this morning, we both agreed that is the best intake. I'll post later how all this turns out.
Old 04-30-2017 | 04:26 PM
  #39
Lot of guys been doing that. Just depends on build/combo and what the engine likes best. Trial and error.
getrdunn is offline
Old 04-30-2017 | 04:39 PM
  #40
Good move mike. I had two on order before I ended up going sc. There an excellent intake with good runner length. Will need a little work though. I run the HV 1200 on my 421 sbc in the 73z. Pulls extremely hard.
getrdunn is offline
