Cam chain clearance to block >
Old 06-30-2018, 05:55 PM
  #41
Originally Posted by Mohavvalley
First off I owe crude intentions an apology, I was wrong, I had my numbers reversed. Mark 4 covers have 10 bolts and the ears for a 2 piece seal, a gen 6 has a 6 bolt cover and no ears for a 1piece seal, AND a gen 5 has 10 bolts and no ears for a 1 piece seal.
Rooster, Eddie Young uses the rollmaster 2095 with a stock gen 6 cover that they clearance the webs on the inside of the cover..... Post #16
Timing set for gen v block with step nose cam
Per Romacusa the CS2090 is the same as the CS2095 but it's not nitrited, I can't verify this though as there only one distributor.
I also called Howard's and they only have a single roller .250 pin, which Eddie Young says the gears are good BUT the chain gets sticky (see above link). Plus according to Howard's there stuff is made by SA gear, so it's basically a SA gear set.
Mike tach, also said that there are two different cam retainer plates. I think this is related to cam end play?
My god this is too complicated for a damn chain, lol!
Baja Rooster is offline
Old 06-30-2018, 06:36 PM
  #42
Howard's 94309 is the one eddie recommended to me last year. This was 1 year ago during my build. I had to trim the ridges inside cover and even he said sometimes you do sometimes you don't but it's easier to do it then have to pull off and check.
Crude Intentions is offline
Old 06-30-2018, 06:37 PM
  #43
https://www.summitracing.com/parts/h...SABEgL1P_D_BwE
this was Eddies description to me
I use a set that is marketed by Howards Cams and sold by Competition Products.It uses virtually the same billet gears as the Rollmaster but uses a Roll-on chain instead of an IWIS chain. And, its almost half the price. The Roll-on chain is every bit as good as the IWIS. Both are German made chains. The Rollmaster set can have some fitment issues with clearing the cam retainer plate. This set does not. The Gen VI is parts # 94309.
Old 07-02-2018, 04:37 PM
  #44
adk61's Avatar
Originally Posted by Crude Intentions
gen 6 blocks but it's a 6 bolt cover. The ribs on the inside need to be ground flat
Gen 6 is a 6 bolt cover... Gen 5 and Mark IV were ten bolt
adk61 is offline
Old 07-02-2018, 04:39 PM
  #45
adk61's Avatar
Right? and ya wonder why I choose the Cloyes!! lolol
adk61 is offline
Old 07-02-2018, 04:41 PM
  #46
adk61's Avatar
So, in the opinion of the OSO brain trust, should I ditch this and go with something else? I really don’t want to yank this thing for such a relatively cheap part.
I still stand by my original statement... Cloyes single roller
adk61 is offline
Old 07-02-2018, 04:43 PM
  #47
adk61's Avatar
No worries. I know that you’re well intended and always helpful. No line boring. I’d have to check the paperwork to see if he honed the caps. I wish I had the funds to buy a full set of heads from you and not worry about it.
I saw a small scratch on the block from just degreeing the cam so I plan on hogging out at least an 1/8” of an inch.
Prepping for surgery.
(905)252-0592... I'm always here to help, boating is my passion, making power is my quest, helping people... my mission!!
adk61 is offline
Old 07-02-2018, 04:55 PM
  #48
F-2 Speedy's Avatar
Received 3,051 Likes on 1,357 Posts
Thats the one Brad Smith recommended when building my 540's.....I was thinking it was a double......to many yrs ago and we all sure miss him
F-2 Speedy is offline
Old 07-02-2018, 05:09 PM
  #49
SB
Received 3,116 Likes on 1,403 Posts
I've done stuff like that myself...reluctantly...but turned out okay. Even with taping off areas, i have vacuum in my left hand and grinder in my right, Make sure to have them real close to each other The metal flies to the left for the most part. And the vac catches a lot of it.
I do the same when scraping gaskets on a motor. No grinder though. Hah.
Work pretty slick.
SB is offline
Old 07-10-2018, 05:01 PM
  #50
Anybody know how many inches deep the stock gen 6 timing cover is?
I've got a gen 5 cover I need to compare to a gen 6 and see if I can fit the rollmaster doubble roller CS2095 under .
Mohavvalley is offline
