milkshake or condensation >
Old 07-10-2018 | 05:31 PM
  #41
Rookie's Avatar
Originally Posted by dereknkathy
ok, rookies pressure tester pics are basically what i did but i used wood instead.
Those are my 3D printed block offs.
And as stated above. Anyone can post pics.
The cracks in my block
Rookie is offline
Old 07-10-2018 | 06:19 PM
  #42
Locknstitch. I have a 502 froze , bought it cheap. Scared up the stuff to fix the cracks. What is that block? Valuable or typical 454? 3D printed, so not metal? It'll hold 50-60 psi though.
dereknkathy is offline
Old 07-10-2018 | 06:56 PM
  #43
Rookie's Avatar
It's just a Gen V that was bored 0.070" and has lasted 20+ yrs. 12 yrs at 600-550HP. It owes me nothing. 50-60 psi on plastic is no problem. I did seal them with Ultra Black.
Rookie is offline
Old 07-10-2018 | 08:01 PM
  #44
A 502 or aftermarket and it has to be considered. That's why i think Tahoe needs to fab a pressure tester and see if the problemo can be isolated.
Old 07-10-2018 | 08:44 PM
  #45
Been there before from frozen blocks. I was looking for an excuse to deep six them anyway. As yours I would think Tahoes would be very visible to the naked eye. I didn't realize that much puke oil was drained. Yikes... I've had reversion back in the day but....
getrdunn is offline
Old 07-10-2018 | 08:52 PM
  #46
What are you power goals.
getrdunn is offline
Old 07-10-2018 | 08:56 PM
  #47
Rookie's Avatar
Originally Posted by Tahoe540
Was looking at a set of the bare ProMaxx so I could just move all of my current head components too as they are still pretty new. Anyone ever use the Sniper heads from PBM?
I have been looking for a drop in or a short block but not too many choices close to me right now.
My head guy uses quite a few ProMaxx and really likes them out of the box for the price. (AFR 315 clone'ish) Might have a pair on the shelf, I know they have been getting popular and lead times are a little out.
Rookie is offline
Old 07-11-2018 | 09:13 AM
  #48
I got 621 HP and 675 lbs of torque out of my 548 with 088 iron heads. I would have to assume a 540 with better heads and cam should bump me up enough to put a smile on my face. I will still go with a small dome piston to be around 10:1 mark depending on the heads.
Here are some of the pics of my setup and it really looks like the intake to head connection was sealed and the head gaskets looked perfect. I have looked over the block and heads with a very bright light looking for a crack or anything weird. I have not found anything. I really think it has to be from the 2 sleeves that were installed in holes 3 and 5. No other invasive machine work was done.
Tahoe540 is offline
Old 07-11-2018 | 09:25 AM
  #49
Dude, why don't you spring for a set of head gaskets, bolt the heads back on and pressure test before you spend big bucks building another motor. If it turns out to be the sleeves they can be redone. It's summertime bud............
payuppsucker is offline
Old 07-11-2018 | 09:46 AM
  #50
I have all the stuff to do it. I can put it back together sometime this week and test it. I do have another boat I bought this spring for the smaller lakes around my area and we have been having fun in that. This boat of heartache is strictly for Lake Tahoe.
Tahoe540 is offline
