2nd time here we go again clanking ticking noise after engine shut down >
Old 09-08-2021 | 12:11 PM
  #91
35fountain's Avatar
Originally Posted by Griff
Roller rockers will fit under the stock Merc valve covers used on Gen V and IV engines. You just need to grind off the drip tabs which is what Merc does this on the blue engines. Not sure it will work on your Mark IV valve covers
I have a set of stamp steel Chrome valve covers no drippers Do you know what kind of roller rockers ?
thx
35fountain is offline
Old 09-09-2021 | 06:29 AM
  #92
35fountain's Avatar
Why was this moved to a different section?
Old 09-09-2021 | 06:52 AM
  #93
because your problem is a tech discussion.
sutphen 30 is offline
Old 09-09-2021 | 07:41 AM
  #94
In another thread the 4 plugs under the lifter valley pan were accidently left out on a gen 6 block causing low oil pressure, if thats what your are asking ?
Yessah. That'd be my knucklehead move. Less than 10 psi with the plugs out then straight up to 65 psi with them back in once I figured it out. Thankfully it was quick...
I always drill the two front galley plugs to put more oil the chain, but it also makes sense that it's to bleed the air out quicker on an initial start. Probably not really necessary for either reason, but I do it anyway.
HawkX66 is offline
Old 09-09-2021 | 09:15 AM
  #95
35fountain's Avatar
ok thanks
Old 09-09-2021 | 09:19 AM
  #96
35fountain's Avatar
So I found these on amazon...Elgin ...the price was very reasonable to try. rated for 700 lbs spring pressure.. Does anyone know if these will fit a Gen IV stock valve cover and do they make a shorter poly lock..
Old 09-09-2021 | 12:47 PM
  #97
thx
Merc used to use Crane Golds. Not sure what mfg they use now.
Griff is offline
Old 09-09-2021 | 12:51 PM
  #98
I tried those once and the poly lock was way to tall for stock valve covers. Notice on the lock that it has a centering ring. Can’t just swap it for a shorter version. Spend the $$$ and get a good set that fits the first time.
endeavor1 is offline
Old 09-09-2021 | 02:18 PM
  #99
35fountain's Avatar
thanks.. crower makes shorter polylocks... i will cancel
Old 09-09-2021 | 02:28 PM
  #100
SB
Be careful, not all rockers will except each others poly locks.
Comp has a set for their rockers I believe. Call'm. :thumbs
SB is online now
