2nd time here we go again clanking ticking noise after engine shut down >
Old 09-07-2021 | 07:01 PM
  #71
SB
Right now $23 per 5qt jug when bought as a 3 pack
https://www.amazon.com/gp/aw/d/B07ZCQZ771 https://www.amazon.com/gp/aw/d/B07ZCQZ771
SB is offline
Old 09-07-2021 | 08:04 PM
  #72
35fountain's Avatar
Got it Thanks
35fountain is offline
Old 09-07-2021 | 08:36 PM
  #73
SB
So, i’m not sure how stock length pushrods ended yp in a motor with heads that have +.100” valves. All else being the same (block and head deck height/etc) height, longer vslves will need longer pushrods. You’d have to go thru that process to determine what length needed.
You shoukd also find what your installed seat and open psi of the springs. The oem rocker arms can only take do much.
When all back fogether, and everything right, if oil is not coning thru rockers enough, tine to pull rngines and see why.
Lastly, just do you know, that worn off rocker arm metal has gone thru your motors.
SB is offline
Old 09-08-2021 | 06:09 AM
  #74
35fountain's Avatar
True...maybe a reason to pull the motors soon. allthough I do change the oil every 20 hours and the filters. Every 10.. I know it's excessive but I don't like when the oil on the stick gets dark.. Probably a waste of a lot of money especially for this oil at $10 a quart but it's worth it for me. This has been an ongoing issue for me for many years and the motors are still together with great oil pressure.
Hopefully the VR1 oil does a better job
Old 09-08-2021 | 06:17 AM
  #75
There was a recent thread on here about a top end oiling problem, turned out to be missing oil galley plugs under the intake.
liberator221 is offline
Old 09-08-2021 | 06:37 AM
  #76
Active Streak: 30 Days
VR1 has a LOT of Zinc in it, a good thing in mho. You may want to use a strait wt like 40. Unless you live and boat in very cold temps. I know a lot of guys who use the Shell Rotella oil, multi wt too.
Helmwurst is offline
Old 09-08-2021 | 06:42 AM
  #77
35fountain's Avatar
many of us run this, Im not a fan of synthetic in a boat
WHY? I believe it's a much better oil
Old 09-08-2021 | 06:43 AM
  #78
offshoredrillin's Avatar
Originally Posted by 35fountain
Can anyone recommend a high zinc oil to replace the amsoil synthetic.. Vr1 20-50 mineral or vr1 synthetic.. or ?? possibly change to a 15/40
amsoil has a high zinc one for engines that sit, hot rod zr is the name
offshoredrillin is offline
Old 09-08-2021 | 06:44 AM
  #79
35fountain's Avatar
Amsoil has 1440 zinc and phosphorus
Old 09-08-2021 | 07:11 AM
  #80
we run shell rotella 15 40 T4 non synthetic in everything even our hard charging high reving 6800 rpm 540
boostbros is offline
